Difference between Cisco Switch Models
devils_advocate
Level 11
Level 11
Can anyone tell me the fundamental differences between the WS-C3750X-48P-L and the WS-C3750X-48P-S switches?
I have checked the compatibility matrix and it seems the differences are listed per image licence but im not sure if that means the
WS-C3750X-48P-L switch cannot use the IP base image?
We just need a L3 switch which does PoE and Intervlan routing, we will use a default route to the router.
Hi:
WS-C3750X-48P-L (Lan Base) / WS-C3750X-48P-S (IP Base)
Lan Base - Full Layer 2 feautures
IP Base   - Full Layer 2 feautures + Basic Layer 3 feautures
If you require dynamic routing for your enterprise access networks, you’ll need to begin with IP Base .
Reggards.
If my answer was helpful, give me point. .
7 Replies 7
Joseph W. Doherty
Disclaimer
The   Author of this posting offers the information contained within this   posting without consideration and with the reader's understanding that   there's no implied or expressed suitability or fitness for any purpose.   Information provided is for informational purposes only and should not   be construed as rendering professional advice of any kind. Usage of  this  posting's information is solely at reader's own risk.
Liability Disclaimer
In   no event shall Author be liable for any damages whatsoever (including,   without limitation, damages for loss of use, data or profit) arising  out  of the use or inability to use the posting's information even if  Author  has been advised of the possibility of such damage.
Posting
As you've surmised, the difference is (factory "installed") license.  The devices are physically identical.
I'm not 100% sure, but I suspect the LANBase license would not work with an IPBase image.  (I also don't recall whether the universal image also provides for LANBase.)
Hi:
Reggards.
devils_advocate
Level 11
Level 11
Ahhh ok, so we could use the LAN Base for our L2 Access Switches which literally do PoE and L2 Vlans and use the IP Base for the Distribution.
We are looking at buying 20-30 of these switches so could save £800 each on the 48 port between the models, hence why I am trying to find out whether we could use the LAN Base at the Access Layer.
Following the Campus Network Design you could be use (for example):
CAMPUS CORE -  WS-C3750X-48T-S OR WS-C3750X-48T-E OR WS-C4500E
          Fast transport
DISTRIBUTION   -   WS-C3750X-48T-S OR WS-C3560X-48T-L
          Inter-VLAN Routing
ACCESS           -   WS-C2960S-48PS-L
         User access to network services and PoE
https://supportforums.cisco.com/docs/DOC-27296
Reggards.
Leo Laohoo
"-L" = LAN Base feature set
"-S" = IP Base feature set
devils_advocate
Level 11
Level 11
Thanks for the helpful replies so far.
Are the licences upgradable?
The reason I ask is that the P-L switch seems to come with the LAN Base Image but we have one onsite which seems to have the IP Base image looking at the #show licence command.
Disclaimer
Posting
Yes.
