c 3750X will not complete image load
Waldini123
I have an issue with a c3750x that was previously working with a good config on it which included the "no ip setup express" command.
Basically now when I boot the switch it gets this far and stops...
Using driver version 1 for media type 2
Base ethernet MAC Address: 44:d3:ca:09:5d:80
Xmodem file system is available.
The password-recovery mechanism is enabled.
Initializing Flash...
mifs[2]: 12 files, 1 directories
mifs[2]: Total bytes     :    2097152
mifs[2]: Bytes used      :     755200
mifs[2]: Bytes available :    1341952
mifs[2]: mifs fsck took 2 seconds.
mifs[3]: 0 files, 1 directories
mifs[3]: Total bytes     :    4194304
mifs[3]: Bytes used      :       1024
mifs[3]: Bytes available :    4193280
mifs[3]: mifs fsck took 3 seconds.
mifs[4]: 5 files, 1 directories
mifs[4]: Total bytes     :     524288
mifs[4]: Bytes used      :       9216
mifs[4]: Bytes available :     515072
mifs[4]: mifs fsck took 1 seconds.
mifs[5]: 5 files, 1 directories
mifs[5]: Total bytes     :     524288
mifs[5]: Bytes used      :       9216
mifs[5]: Bytes available :     515072
mifs[5]: mifs fsck took 1 seconds.
mifs[6]: 7 files, 1 directories
mifs[6]: Total bytes     :   57671680
mifs[6]: Bytes used      :     177664
mifs[6]: Bytes available :   57494016
mifs[6]: mifs fsck took 44 seconds.
...done Initializing Flash.
done.
Loading "flash:c3750e-universalk9-mz.122-58.SE2.bin"...@@@
I am unable to halt the boot process (with the break sequence ) and get in to ROMMON mode and the MODE button on the front of the switch isnt allowing me to break the boot sequence either.
If anyone out there can offer any suggestions I'd be very grateful.  Thanks.
Paul
Leo Laohoo
Try this ... Stand the appliance on the Mode button and power it up.  Wait for 30 seconds and see whether or not the appliance goes into a full-blown factory reset.
If not, then I recommend you contact Cisco and get the appliance RMA-ed.
And by the way, please avoid (at all cost) using IOS version 12.2(58)SE and later.  If you need a stable IOS version, try 12.2(55)SE8 or 15.0(2)SE4.  Don't even attempt to try anything else.
