C-4503 VSS stuck in reload loop
Tomas Bulla
I have 2 4503 switches configured in VSS that was working normally. I need to update license to enterprise so it supports BGP. After I enabled license I put the switch in reload. Following output is from the primary switch as I have no working OOB to secondary switch and I have no way to tell what is happening there:
Initializing as Virtual Switch STANDBY processor
% Invalid input detected at '^' marker.
*Aug 18 02:55:38.249: %C4K_IOSINTF-5-LMPHWSESSIONSTATE: Lmp HW session UP on slot 1 port 4.
*Aug 18 02:55:38.262: %C4K_IOSINTF-5-LMPHWSESSIONSTATE: Lmp HW session UP on slot 1 port 3.
*Aug 18 02:55:54.244: %VSLP-5-VSL_UP:  Ready for control traffic
*Aug 18 02:55:57.260: %VSLP-5-RRP_ROLE_RESOLVED: Role resolved as STANDBY by VSLP
*Aug 18 02:56:37.595: %C4K_REDUNDANCY-3-COMMUNICATION: STANDBY:Communication with the peer Supervisor has been established
*Aug 18 02:56:38.288: %C4K_REDUNDANCY-2-VS_REBOOT_ON_RPR_FALLBACK: STANDBY:Supervisor in virtual-switch configuration cannot operate in redundancy mode RPR, will be reset
*Aug 18 02:56:38.559: %RF-5-RF_RELOAD: STANDBY:Self Reload. Reason: Virtual-switch fallback to RPR
*Aug 18 02:56:38.606: %SYS-5-RELOAD: STANDBY:Reload requested by Platform redundancy manager. Reload Reason: Virtual-switch fallback to RPR.
<Thu Aug 18 02:56:39 2016> Message from sysmgr: Reason Code:[3] Reset Reason:Reset/Reload requested by [console]. [Reload command]
umount: /proc/fs/nfsd: not mounted
Not sure why this is happening, and how to perform the license update so it doesn't happen again, as I need to do the same in my 2nd DC.
shafiq_84
***I HAVE THE SAME PROBLEM**
Platform Manager: starting in VSS mode (chassis id 2, in-chassis active)
Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
cisco Systems, Inc.
170 West Tasman Drive
San Jose, California 95134-1706
Cisco IOS Software, IOS-XE Software, Catalyst 4500 L3 Switch Software (cat4500es8-UNIVERSALK9-M), Version 03.07.03.E RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2016 by Cisco Systems, Inc.
Compiled Thu 14-Jan-16 06:17 by prod_rel_team
Cisco IOS-XE software, Copyright (c) 2005-2015 by cisco Systems, Inc.
All rights reserved. Certain components of Cisco IOS-XE software are
licensed under the GNU General Public License ("GPL") Version 2.0. The
software code licensed under GPL Version 2.0 is free software that comes
with ABSOLUTELY NO WARRANTY. You can redistribute and/or modify such
GPL code under the terms of GPL Version 2.0.
(http://www.gnu.org/licenses/gpl-2.0.html) For more details, see the
documentation or "License Notice" file accompanying the IOS-XE software,
or the applicable URL provided on the flyer accompanying the IOS-XE
software.
*May 19 13:20:58.186: %C4K_IOSMODPORTMAN-4-POWERSUPPLYBAD: Power supply 2 has failed or been turned off
*May 19 13:22:00.987: %C4K_IOSINTF-5-LMPHWSESSIONSTATE: Lmp HW session UP on slot 13 port 1.
*May 19 13:22:01.022: %C4K_IOSINTF-5-LMPHWSESSIONSTATE: Lmp HW session UP on slot 13 port 2.
*May 19 13:22:16.988: %VSLP-5-VSL_UP: Ready for control traffic
*May 19 13:22:20.991: %VSLP-5-RRP_ROLE_RESOLVED: Role resolved as STANDBY by VSLP
*May 19 13:22:58.385: %C4K_REDUNDANCY-2-IOS_VERSION_CHECK_FAIL: STANDBY:IOS version mismatch. Active supervisor version is 15.2(3)E3 (cat4500es8-UNIVERSAL-M). Standby supervisor version is 15.2(3)E3 (cat4500es8-UNIVERSALK9-M). Redundancy feature may not work as expected.
*May 19 13:22:58.385: %C4K_REDUNDANCY-2-NON_SYMMETRICAL_REDUNDANT_SYSTEM: STANDBY:STANDBY supervisor will operate in fallback redundancy mode rpr.
*May 19 13:23:02.404: %C4K_REDUNDANCY-3-COMMUNICATION: STANDBY:Communication with the peer Supervisor has been established
*May 19 13:23:02.826: %C4K_REDUNDANCY-2-VS_REBOOT_ON_RPR_FALLBACK: STANDBY:Supervisor in virtual-switch configuration cannot operate in redundancy mode RPR, will be reset
*May 19 13:23:02.868: %RF-5-RF_RELOAD: STANDBY:Self Reload. Reason: Virtual-switch fallback to RPR
*May 19 13:23:02.960: %SYS-5-RELOAD: STANDBY:Reload requested by Platform redundancy manager. Reload Reason: Virtual-switch fallback to RPR.
<Sat May 19 13:23:03 2018> Message from sysmgr: Reason Code:[3] Reset Reason:Reset/Reload requested by [console]. [Reload command]
****THIS PROCESS REPEATING UNTIL I RESET BACK TO STANDALONE***
**ANYONE HAVE THE SOLUTION FOR THIS !!??
