C1000 no web UI or 404 not found after write erase
ChrisAG
Hello, I have a new Catalyst C1000-24T-4G-L, running 15.2-7. I cannot seem to get the switch back into the mode where I can access the Web GUI/Configuration Wizard.
Out of the box I was able to utilize the Web GUI and go through the Configuration Wizard. I had made some unknown mistakes preventing me from accessing the switches webpages. So....
Since then, i have reset the switch utilizing the write erase commands and deleting the vlan configs. rebooting etc.
I've ran through the following script:https://www.cisco.com/c/en/us/td/docs/routers/access/1100/software/configuration/xe-16-10/cisco_1100_series_swcfg_xe_16_10_x/cisco_1100_series_swcfg_xe_16_10_x_chapter_011001.html to no avail.
When I type the web addresses "https://192.168.1.1/webui/#/dayZeroRouting" or "http://192.168.1.1/webui/#/dayZeroRouting" I get a 404 not found. (yes, I can ping the switch)
When I type 192.168.1.1, it continuously prompts me for credentials, which I enter as 'webui' and 'cisco'. See Capture.PNG
It seems as if the http package/gui is empty on the switch, but I don't understand how you would turn it or or enable it.
I saw a thread where a user had upgraded  their switch and couldn't reach the web gui, so the answer was to download a different image. But that seems odd to me it could be the answer since I haven't gone through any updates or downloaded a different firmware etc.
Any help would be greatly appreciated!!
Below is the config:
Switch#show config
Using 1822 out of 524288 bytes
! Last configuration change at 15:38:31 UTC Thu Aug 11 2022
version 15.2
no service pad
hostname Switch
boot-start-marker
boot-end-marker
username webui privilege 15 secret 9 $9$Y7yvhfhZR0Km2S$11qFLzI0yUPxW5/GAh6FRR5M4YIFN1ZsNnHfUh/AOR.
no aaa new-model
switch 1 provision c1000-24t-4g-l
system mtu routing 1500
ip dhcp excluded-address 192.168.1.1 192.168.1.5
ip dhcp pool WEBUIPool
network 192.168.1.0 255.255.255.0
default-router 192.168.1.1
dns-server 192.168.1.1
spanning-tree mode rapid-pvst
vlan internal allocation policy ascending
interface GigabitEthernet1/0/1
interface GigabitEthernet1/0/2
interface GigabitEthernet1/0/3
interface GigabitEthernet1/0/4
interface GigabitEthernet1/0/5
interface GigabitEthernet1/0/6
interface GigabitEthernet1/0/7
interface GigabitEthernet1/0/8
interface GigabitEthernet1/0/9
interface GigabitEthernet1/0/10
interface GigabitEthernet1/0/11
interface GigabitEthernet1/0/12
interface GigabitEthernet1/0/13
interface GigabitEthernet1/0/14
interface GigabitEthernet1/0/15
interface GigabitEthernet1/0/16
interface GigabitEthernet1/0/17
interface GigabitEthernet1/0/18
interface GigabitEthernet1/0/19
interface GigabitEthernet1/0/20
interface GigabitEthernet1/0/21
interface GigabitEthernet1/0/22
interface GigabitEthernet1/0/23
interface GigabitEthernet1/0/24
interface GigabitEthernet1/0/25
interface GigabitEthernet1/0/26
interface GigabitEthernet1/0/27
interface GigabitEthernet1/0/28
interface Vlan1
ip nat inside
ip http server
ip http secure-server
line con 0
line vty 5 15
end
Switch#
Jitendra Kumar
delete /f /r flash:c1000-universalk9-mz.152-7.E*.bin
archive download-sw /leave flash:c1000-universalk9-tar.152-7.E5.tar
2nd command will unpack the HTML process will take time around 10 to 15 minutes.
once unpacking done reboot switch.
Jitendra
since I do not see that in the configuration you have posted, do you have:
ip http authentication local
configured ?
amde
yes i had same problem. ip http authentication local was missing . after providing , i am able to access. thanks
