06-22-2022 05:07 AM
we want to connect two C1000-48P-4X-L switches over fiber and are using the following transceivers (10GTek 10G SFP+ SR Multimode Modul - 10GBase-SR LC Transceiver Kompatibel für Cisco SFP-10G-SR).
Transceivers are shown and recognized but do the LEDs by the GBICs have to blink and what type of port do we have to configure, we have set trunk.
06-22-2022 05:26 AM
- For starters, have an in-depth check of sfp-compatibility with : https://tmgmatrix.cisco.com/
M.
06-22-2022 05:43 AM
We had a look before we bought the transceivers. The current inserted have the supported IEEE 10GBASE-SR standard.
850nm, 300m MMF.
Is there anything I do miss?
06-22-2022 05:59 AM - edited 06-22-2022 09:19 AM
- If they are not Cisco, success is not guaranteed you may use commands as
no errdisable detect cause sfp-config-mismatch
no errdisable detect cause gbic-invalid
Not sure if that will help
M.
07-06-2022 03:32 AM
I did connect both switches directly via LC/LC cable and that did work.
Then I moved one switch to the other location, connected via SC/LC - no link is comming up. Then I ran the commands above, wr mem and did a reload on both switches. No link after the restart.
Now I guess it could be something with the inhouse lwl cable but it was tested already by lwl technician.
Maybe the lengh is too high? I have no further ideas.
