C2651 Unknown Protocol Drops
ldengming
Please help and advise. I am unable to connect any device on both my fa0/0 and fa0/1. Is it a hardware failure?
FastEthernet0/0 is up, line protocol is up
  Hardware is AmdFE, address is 0013.7f8e.3660 (bia 0013.7f8e.3660)
  Internet address is 192.168.1.1/24
  MTU 1500 bytes, BW 100000 Kbit/sec, DLY 100 usec,
  Keepalive set (10 sec)
  Full-duplex, 100Mb/s, 100BaseTX/FX
  Last input 00:00:02, output 00:00:02, output hang never
  Last clearing of "show interface" counters 00:44:24
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
     2112 packets input, 429469 bytes
     Received 2112 broadcasts, 0 runts, 0 giants, 0 throttles
     0 watchdog
     315 packets output, 32310 bytes, 0 underruns
     2105 unknown protocol drops
     0 lost carrier, 0 no carrier
6 Replies 6
Reza Sharifi
Have a look at this post with the same issue:
https://supportforums.cisco.com/thread/139568
My packets are entirely dropped including ICMP Echo and ARP not just DTP, CDP packets.
     6142 packets input, 1255543 bytes
     Received 6142 broadcasts, 0 runts, 0 giants, 0 throttles
     6124 unknown protocol drops
I  directly connected a laptop to the port and ping but the pings were dropped as well.
Can you post "sh run" from the router?
Thanks Reza. For your reference
Current configuration : 1216 bytes
version 12.4
hostname
boot-start-marker
boot-end-marker
enable secret 5
enable password
no aaa new-model
memory-size iomem 30
clock save interval 8
no network-clock-participate slot 1
no network-clock-participate wic 0
ip cef
no ip domain lookup
archive
log config
  hidekeys
interface FastEthernet0/0
ip address 10.0.1.3 255.255.255.0
duplex auto
speed auto
no mop enabled
interface Serial0/0
no ip address
shutdown
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface Serial0/1
no ip address
shutdown
ip forward-protocol nd
no ip http server
no ip http secure-server
control-plane
line con 0
exec-timeout 0 0
password
logging synchronous
login
speed 115200
line aux 0
line vty 0 4
exec-timeout 0 0
password
logging synchronous
login
line vty 5 15
exec-timeout 0 0
password
logging synchronous
login
end
On your first post you have:
On your last post you have:
are these both from the same router?
If yes, try this command
mop enabled
and test again
Thanks but I found an anomaly that suggests its a main board issues.
I debug arp and saw the ping address alway show incomplete. I used wireshark to capture the ping packet and found 2 of the bits always set as 1.
For broadcast to 0000.0000.0000, the packet destination is 0002.0000.0002. I tried to key in static arp entry and observed the following:
For mac target 4F6D became 4F6F but 4F6B is correctly transmitted. I think the 2nd least significant bit of the 4th hex value is always 1.
Likewise if mac end with A, its transmitted correctly but 0 changes to 2 and 9 become B. Hence, the 2nd bit in the last hex is again always 1.
Unfortunately I think my router is defective. Repair is probably not worth it.
