C2801 not booting up completely
Dikkeknikker
Yesterday a coleagu accdently removed the CF card from the router now the router does no longer want to boot completely.
It extracts the image from the CF card but when it has to initialize the configuration it stucks there for hours. Can it be that the startup config is somehow corrupted?
Anyone any idea how to solve this?
When i try to tftpdnld is says that the mac address is illegal.
The first line of the cookie looks like 04 ff 08 86 ff ff ff ff ff ff ff ff ff ff ff ff
System Bootstrap, Version 12.4(13r)T, RELEASE SOFTWARE (fc1)
Copyright (c) 2006 by cisco Systems, Inc.
PLD version 0x10
GIO ASIC version 0x127
c2801 platform with 196608 Kbytes of main memory
Main memory is configured to 64 bit mode with parity disabled
Readonly ROMMON initialized
program load complete, entry point: 0x8000f000, size: 0xcb80
program load complete, entry point: 0x8000f000, size: 0x18190d4
Self decompressing the image : #################################################        ################################################################################        ################################################################################        ################################################################ [OK]
Smart Init is enabled
smart init is sizing iomem
  ID            MEMORY_REQ         TYPE
                0X003AA110 public buffer pools
                0X00211000 public particle pools
                0X00020000 Crypto module pools
                0X00120000 VPM buffer pools
0X04C8          0X00077D00 Card in slot 1
0X0002          0X0001A800 Card in slot 2
0X0056          0X00035600 Card in slot 3
                0X000021B8 Onboard USB
If any of the above Memory Requirements are
"UNKNOWN", you may be using an unsupported
configuration or there is a software problem and
system operation may be compromised.
Allocating additional 10161685 bytes to IO Memory.
PMem allocated: 180355072 bytes; IOMem allocated: 20971520 bytes
              Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
           cisco Systems, Inc.
           170 West Tasman Drive
           San Jose, California 95134-1706
Cisco IOS Software, 2801 Software (C2801-SPSERVICESK9-M), Version 12.4(4)T7, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2006 by Cisco Systems, Inc.
Compiled Tue 28-Nov-06 19:04 by kellythw
Image text-base: 0x6008B7DC, data-base: 0x62680000
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
If i remove the CF to enter rommon mode i get the following :
rommon 1 > dir flash:
Directory of flash:
2 25268852 -rw- c2801-spservicesk9-mz.124-4.T7.bin
6540 2746 -rw- sdmconfig-2801.cfg
6541 931840 -rw- es.tar
6769 1505280 -rw- common.tar
7137 1038 -rw- home.shtml
7138 112640 -rw- home.tar
7166 1697952 -rw- securedesktop-ios-3.1.1.45-k9.pkg
7581 415956 -rw- sslclient-win-1.1.4.176.pkg
6172 780 -rw- vlan.dat
7 Replies 7
Raju Sekharan
Try to boot the router by skipping the config (set  the config-register to 2142 )
Thank you
Raju
I have already done that. I think the cookie is maybe wrong. I got al FFFF where there should be a good format.
Does anyone have a 2801 and is able to compare his first row with mine?
I think, the image on the CF is corrupted.  You need to erase and format it.  Then copy an image to it from another router and than try to boot it. Do you have another router with CF card in it?
Yes i have a 1841 with CF. Don't know if they support the same format. I thought the 1841 is  erase and not format class C.
Could you in the meanwhile compare my cookie with yours if you have a 2801  ? Because i compared it with a cookie form the 1841 and the FF FF in the first line is strange. It should give a valid mac address  there.
Greets
I have a 2821.  How do you compare the cookies?
In Rommon you can give the command "cookie"
for example: rommon1 >cookie
then you get a whole lot of  digits.. could you send me the first row of 16 pairs.
Got is working guys. Finally someone gave me his cookie
