is cisco 7600 a switch or router or MLS or layer3 switch ??
Dr.X
Level 2
Level 2
hi ,
i want to ask about cisco 7600 model
is it a switch or  router or layer3 switch or Multilayer switch ??????
which one is it ??
here is the sh version :
Gateway7600#sh version
Cisco IOS Software, c7600s3223_rp Software (c7600s3223_rp-ADVENTERPRISEK9-M), Version 15.2(1)S, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2011 by Cisco Systems, Inc.
Compiled Sun 27-Nov-11 15:27 by prod_rel_team
ROM: System Bootstrap, Version 12.2(17r)SX3, RELEASE SOFTWARE (fc1)
BOOTLDR: Cisco IOS Software, c7600s3223_rp Software (c7600s3223_rp-ADVENTERPRISEK9-M), Version 15.2(1)S, RELEASE SOFTWARE (fc1)
Gateway7600 uptime is 15 weeks, 2 days, 9 hours, 48 minutes
Uptime for this control processor is 15 weeks, 2 days, 9 hours, 48 minutes
System returned to ROM by power-on (SP by power-on)
System restarted at 12:29:22 UTC Sat Aug 4 2012
System image file is "sup-bootdisk:c7600s3223-adventerprisek9-mz.152-1.S.bin"
Last reload type: Normal Reload
Last reload reason: power-on
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco CISCO7604 (R7000) processor (revision 2.0) with 458752K/65536K bytes of memory.
Processor board ID FOX1509G2DK
R7000 CPU at 300MHz, Implementation 39, Rev 3.3, 256KB L2, 1024KB L3 Cache
Last reset from power-on
1 Virtual Ethernet interface
9 Gigabit Ethernet interfaces
1915K bytes of non-volatile configuration memory.
65536K bytes of Flash internal SIMM (Sector size 512K).
regards
Sandeep Choudhary
Its a router.
here u can see the feature and benifits:
http://www.cisco.com/en/US/products/ps6316/index.html
Reagrds
Please rate if it helps.
Jon Marshall
The 7600 is in effect a router but it does it's routing in hardware so it could be referred to as a L3 switch in that regard.
Best to think of it as a hardware router as it is concentrated more on L3 routing than L2 switching. It is similiar to a 6500 switch but supports additional interfaces which may be used to terminate non ethernet connectivity and has a different IOS which would support more WAN based technologies.
But it is still a chassis based device and will support ethernet modules as with the 6500.
Jon
