c2950-i6q4l2-mz.121-22.EA10a.bin
vipinrajrc
Level 3
Level 3
Hi Experts,
c2950-i6q4l2-mz.121-22.EA10a.bin is the image name of the 2950 switch i have in my office. what is the meaning of " i6q4l2 "? I saw some IOS like IP base, adv-security. but i didnt see anything like this before.
Please advice.
Thanks&Regards
Vipin
Thanks and Regards, Vipin
Somasundaram Jayaraman
The IOS file name is usually similar to this form:
xxxx-yyy-ww.aaa-bb.bin
1. The xxxx is the platform. For example:
c2500 – For 25xx, 3xxx, 5100, and AO (11.2 and later only) platforms
c2600 – For 2600 platform
2. The yyy is the feature set. For example,
b For Apple talk support
boot For boot image
c For CommServer lite (CiscoPro)
drag For IOS based diagnostic image
g For ISDN subset (SNMP, IP, Bridging, ISDN, PPP, IPX, and AppleTalk)
i For IP subset (SNMP, IP, Bridging, WAN, Remote Node, and Terminal Services)
n For IPX support
q For asynchronous support
t For Telco return (12.0)
y For reduced IP (SNMP, IP RIP/IGRP/EIGRP, Bridging, ISDN, and PPP) (c1003 or c1004)
z For managed modems
40 For 40 bit encryption
50 For 50 bit encryption
3. The ww is for the format (where the IOS file runs in the router)
f For flash
m For RAM
r For ROM
l For the image will be relocated at run time
The file might also be compressed. The following letters denote the compression type,
z For zip compression
x For mzip compression
w For “STAC” compression
aaa-bb represent the version of the IOS. It is usually read like this “Version aa.a(bb)”. The last part of the IOS file name might contain letters like T (new feature release identifier), S (individual release number), or XR (modular packages).
Reference links:
- http://www.cisco.com/web/learning/le21/le34/downloads/689/academy/2005/BRK-101.pdf
Hope this answers your question.
Cheers
Somu
Rate helpful posts
glen.grant
  Thats the non crypto version of the image for your platform , crypto version has a slightly diffrent name  like
c2950-i6k2l2q4-mz.121-22.EA14.bin .
