C2950 IOS for DHCP Snooping and DAI
johnlloyd_13
Level 9
Level 9
hi all,
anyone knows what image i would need for my 2950 to enable DHCP snooping and DAI features (just for lab purpose)?
or are these features just available on the bigger modular switches (4500 and 6500)?
>sh ver
IOS (tm) C2950 Software (C2950-I6Q4L2-M), Version 12.1(22)EA8a, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2006 by cisco Systems, Inc.
Compiled Fri 28-Jul-06 15:16 by weiliu
Image text-base: 0x80010000, data-base: 0x8056A000
Switch(config)#ip dhcp snooping ?
  information  DHCP Snooping information
  vlan         DHCP Snooping vlan
  <cr>
Switch(config)#ip arp ?
% Unrecognized command
2 Accepted Solutions
cadet alain
you need 121-19.EA1 image for DHCP snooping and DAI is not available on this platform according to Cisco feature navigator.
Regards.
Alain
Not  in a near future  because i'm preparing for another cert right now .
I think that 3550 should be enough for 99 % of the exam features.
Regards.
Alain
cadet alain
Regards.
Alain
Hi Alain,
Thanks for this info! I've read you're CCNA Security.
Just curious, are you gonna write your CCNP Security soon?
Could you recommend a good lab switch for SECURE?
Regards.
Alain
Alain,
Thanks for the advice!
And good luck to the cert you'll write soon!
Cheers!
