c2960 duplex mismatch errors
j.walmsley
I have a ws-c2960g-48 tc-l software ver 12.2.25 SEE3 that when I use SFP GLC-GE-100FX I get duplex errors ports 45-48 do not have the option to set duplex full on them. How do you change duplex from auto to duplex full on them?
JORGE RODRIGUEZ
Level 10
Level 10
Jim,
Under the interface specify the media type ( media-type sfp ) then try changing settings see if that works.
go through this document for reference
http://www.cisco.com/en/US/docs/switches/lan/catalyst2960/software/release/12.2_25_see/configuration/guide/swint.html
Jorge
Jorge Rodriguez
JORGE RODRIGUEZ
Level 10
Level 10
Jim,
Jorge
Jorge Rodriguez
Jorge
Thanks for the quick answer. That was the proplem I can now change duplex
Thanks again
Jim
