C2960 serie IOS Upgrade and no more GUI
Nicky Maddison
I have several Cisco Catalyst 2960 and I would like to upgrade them to the latest version of IOS.
I managed to upgrade one of them to version 15.0(2)SE10a, it is working fine and my configuration has not been corrupted or deleted.
I am using the "c2960-lanbasek9-tar.150-2.SE10a.tar" image because I need the web GUI for non IT users.
Unfortunately, after the upgrade, I get this
instead of the trendy HTML web interface.
I have checked in the flash and the "html" folder is present and in the config, the "ip http path flash:" in also in the config.
How can i get the trendy web gui back?
Thanks a lot.
ktonev
Please post your question in the main Switching forum so it can get the appropriate visibility and get answered faster. The Catalyst series are an Enterprise product and you have posted your question in the Small Business section.
Kris
OK thanks
