12-14-2020 12:16 AM
I have a C2960L-SM and noticed that I can't connect over ssh anymore. I get
ssh_exchange_identification: Connection closed by remote host
If I run show ip ssh it seems ssh is running:
SSH Enabled - version 1.99 ... and so on
What can I do? Especially with this smart managed switch, where I have only resticted access to CLI?
best regards,
tokon
Solved! Go to Solution.
12-20-2020 06:35 AM
I have testet some things over the weekend:
- factory reset - ssh still not working
- downgrade to 15.2(7)E2 - ssh is working
So it's either a firmware bug or they have removed ssh with 15.2(7)E3 for this switch model.
12-14-2020 12:39 AM
what is the version of code running, if you have only ipbase image this may not required, it required k9 image to enable ssh to work.
can you post below output :
show version
show run | in ssh
show ssh
12-14-2020 01:14 AM
Mon Dec 14 2020 10:09:17 GMT+0100 (Mitteleuropäische Normalzeit)
#show version
Cisco IOS Software, C2960L Software (C2960L-UNIVERSALK9-M), Version 15.2(7)E3, RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2020 by Cisco Systems, Inc.
Compiled Sun 06-Sep-20 11:19 by prod_rel_team
ROM: Bootstrap program is C2960L boot loader
BOOTLDR: C2960L Boot Loader (C2960L-HBOOT-M) Version 15.2(6r)E1, RELEASE SOFTWARE (fc1)
Switch uptime is 10 hours, 31 minutes
System restarted at 23:37:50 GMT Sun Dec 13 2020
System image file is "flash:c2960l-universalk9-mz.152-7.E3/c2960l-universalk9-mz.152-7.E3.bin"
Last reload reason: Reload command
Switch Ports Model SW Version SW Image
* 1 28 WS-C2960L-SM-24PS 15.2(7)E3 C2960L-UNIVERSALK9-M
Configuration register is 0xF
Mon Dec 14 2020 10:12:35 GMT+0100 (Mitteleuropäische Normalzeit)
#show run | in ssh
(no output)
Mon Dec 14 2020 10:13:05 GMT+0100 (Mitteleuropäische Normalzeit)
#show ssh
%No SSHv2 server connections running.
12-14-2020 01:43 AM
i do not see SSH running, can you post
#show license
12-14-2020 01:52 AM
command not possible on this switch.
Mon Dec 14 2020 10:51:22 GMT+0100 (Mitteleuropäische Normalzeit)
#show license
Invalid input detected.
12-14-2020 04:49 AM
something looks odd here...can you post show run
12-14-2020 06:59 AM
If I compare show run with an old config backup there is something missing.
After "crypto pki certificate chain TP-self-signed-958090880" the backup contains:
certificate self-signed 01
30820229 30820 ......
This part is missing now. A few month ago ssh was working, I think it's broken with the last firmware update.
Mon Dec 14 2020 15:44:37 GMT+0100 (Mitteleuropäische Normalzeit)
#show run
Building configuration...
Current configuration : 4171 bytes
! Last configuration change at 23:38:20 GMT Sun Dec 13 2020
version 15.2
no service pad
hostname Switch
boot-start-marker
boot-end-marker
enable secret 9 xyz
username user privilege 15 secret 9 xyz
no aaa new-model
clock timezone GMT 1 0
clock summer-time GMT recurring
system mtu routing 1500
ip dhcp pool mgmt_pool
network 192.168.1.0 255.255.255.0
default-router 192.168.1.1
dns-server 192.168.1.1
lease 0 0 1
ip igmp snooping vlan 2 mrouter learn cgmp
energywise domain cisco security shared-secret 0 cisco
crypto pki trustpoint TP-self-signed-958090880
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-958090880
revocation-check none
rsakeypair TP-self-signed-958090880
spanning-tree mode rapid-pvst
vlan internal allocation policy ascending
interface Bluetooth0
no ip address
shutdown
interface GigabitEthernet0/1
description Esszimmer Gast LAN
switchport access vlan 2
switchport mode access
spanning-tree portfast edge
interface GigabitEthernet0/2
description Esszimmer LAN
interface GigabitEthernet0/3
interface GigabitEthernet0/4
description Buero AP
switchport trunk allowed vlan 1,2
switchport mode trunk
interface GigabitEthernet0/5
interface GigabitEthernet0/6
interface GigabitEthernet0/7
description Buero PC
interface GigabitEthernet0/8
description Buero Telefon
interface GigabitEthernet0/9
description Wohnzimmer Switch
interface GigabitEthernet0/10
description Wohnzimmer AP
interface GigabitEthernet0/11
description Buero Drucker
interface GigabitEthernet0/12
description Buero Raspi
interface GigabitEthernet0/13
description Schlafzimmer ATV
interface GigabitEthernet0/14
interface GigabitEthernet0/15
description Keller
interface GigabitEthernet0/16
description Gang
interface GigabitEthernet0/17
description Kinderzimmer AP
interface GigabitEthernet0/18
description Keller Switch
interface GigabitEthernet0/19
description USV
interface GigabitEthernet0/20
description TK Anlage
interface GigabitEthernet0/21
description NAS Synology
interface GigabitEthernet0/22
description NAS Qnap
interface GigabitEthernet0/23
description Fritzbox LAN1
interface GigabitEthernet0/24
description Fritzbox LAN4 Gast
interface GigabitEthernet0/25
interface GigabitEthernet0/26
interface GigabitEthernet0/27
interface GigabitEthernet0/28
interface Vlan1
ip address 192.168.222.2 255.255.255.0
ip default-gateway 192.168.222.1
ip http server
ip http banner
ip http authentication local
ip http secure-server
ip scp server enable
line con 0
password xyz
line vty 0 4
privilege level 15
login local
transport input none
line vty 5 15
privilege level 15
login local
ntp server 129.143.2.33 source Vlan1
ntp server 129.69.1.153 source Vlan1
ntp server 129.143.2.23 source Vlan1
end
04-23-2024 06:25 AM
Look under line vty 0 4 and line vty 5 15:
it says "transport input none" - meaning that it does not accept any incoming session to the device
you need to go on console, log in and the do this:
conf t
line vty 0 15
transport input ssh
end
wr mem
Then it shouæld be possible to login with ssh
You could also do "transport input all"; then you can use telnet as well and ensure crypto keys, in case they should be missing
I've seen some times that an upgrade of switches that had "transport input ssh" ends up with "transport input none" after the upgrade.
12-14-2020 12:45 AM
sounds like you only have limited access to the switch, but check if you can zeroize and regenerate the RSA keys, that sometimes helps:
crypto key zeroize rsa
crypto key generate rsa
12-14-2020 01:18 AM
This doesn't work with this smart managed switch.
But I can "Renew Certificate" over the web gui. It's maybe the same. I get two alerts "ssh disabled" and "ssh enabled", but ssh is still not working.
12-14-2020 03:47 AM
- Enable and or use a ssh-client which supports debugging, you may get extra info's
M.
12-14-2020 04:11 AM
on my MacBook with option -v
OpenSSH_8.1p1, LibreSSL 2.7.3
debug1: Reading configuration data /etc/ssh/ssh_config
debug1: /etc/ssh/ssh_config line 47: Applying options for *
debug1: Connecting to 192.168.222.2 [192.168.222.2] port 22.
debug1: Connection established.
debug1: identity file /Users/mylocaluser/.ssh/id_rsa type -1
debug1: identity file /Users/mylocaluser/.ssh/id_rsa-cert type -1
debug1: identity file /Users/mylocaluser/.ssh/id_dsa type -1
debug1: identity file /Users/mylocaluser/.ssh/id_dsa-cert type -1
debug1: identity file /Users/mylocaluser/.ssh/id_ecdsa type -1
debug1: identity file /Users/mylocaluser/.ssh/id_ecdsa-cert type -1
debug1: identity file /Users/mylocaluser/.ssh/id_ed25519 type -1
debug1: identity file /Users/mylocaluser/.ssh/id_ed25519-cert type -1
debug1: identity file /Users/mylocaluser/.ssh/id_xmss type -1
debug1: identity file /Users/mylocaluser/.ssh/id_xmss-cert type -1
debug1: Local version string SSH-2.0-OpenSSH_8.1
kex_exchange_identification: Connection closed by remote host
12-14-2020 07:33 AM
Hm, the debugging capabilities seem somewhat limited , advising to debug-test with putty or native ssh (client) on Linux, yet it seems already somewhat listing as to which ciphers are being used -> you can get more info on that with :
% nmap --script ssh2-enum-algos switch
- Usually the problem is due to an available cipher mismatch between the ssh-client and the ssh-server
M.
12-14-2020 08:00 AM
This is showing:
$ nmap --script ssh2-enum-algos 192.168.222.2
Starting Nmap 7.40 ( https://nmap.org ) at 2020-12-14 16:56 CET
Nmap scan report for 192.168.222.2
Host is up (0.060s latency).
Not shown: 997 closed ports
PORT STATE SERVICE
22/tcp open ssh
80/tcp open http
443/tcp open https
Nmap done: 1 IP address (1 host up) scanned in 9.68 seconds
12-15-2020 12:24 AM
You mentioned this did not work, can you describe why and or which errors are seen when using those commands ?
M.
