C2960L-SM - ssh connection not possible
tokon
I have a C2960L-SM and noticed that I can't connect over ssh anymore. I get
ssh_exchange_identification: Connection closed by remote host
If I run show ip ssh it seems ssh is running:
SSH Enabled - version 1.99 ... and so on
What can I do? Especially with this smart managed switch, where I have only resticted access to CLI?
best regards,
tokon
23 Replies 23
This is caused to the limited CLI access of this smart switch:
Switch#configure terminal
% Invalid input detected at '^' marker.
Switch#crypto key zeroize rsa
                   - As you say , you need sufficient privileges to carry on with that.
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
make sure you login user with privilege 15
BB
pieterh
do you have any other SMART switches in your network ?
if so you may need to connect to the "director" to manage the switch
No, I have only this switch.
tokon
I have testet some things over the weekend:
- factory reset - ssh still not working
- downgrade to 15.2(7)E2 - ssh is working
So it's either a firmware bug or they have removed ssh with 15.2(7)E3 for this switch model.
Threre has been a change in default behavior, I also learned it the hard way
In older releases, ssh and telnet input transports were enabled by default without any explicit config under line vty. With more recent images (I only tried 15.2.(7)E6)), if the startup config has no explicit "transport input xxx" config under vty line, it becomes "transport input none" when the image boots and no remote access is allowed.  CSCvv00134 might be related, although it says ssh will be enabled by default which isn't, so I cannot really tell what exactly it is doing, I no longer have access to internal cisco ddts database...
So configure "transport input ssh" or "transport input all" prior upgrading, otherwise the remote access is lost after the upgrade.
chances are that you have indeed hit a bug. Actually, 15.2.7E2 MD (and not E3) is the recommended release).
Henning-Kihle
Hi.
This command does the trick, all software after 15.2(7)E0a
Lne vty 0 4 (5 15)
  transport input ssh
Does not show in "show run" later but works
