C2960x flash corrupted
nijamudeen_aziz
Flash corrpted during software update and switch got struck even after reflash via xmodem.
13 Replies 13
M02@rt37
Hello @nijamudeen_aziz
Use FAT16 system on a usb stick (max 2GB capacity). Copy the *.bin file on it and punt it into the switch usb port. Start the switch and enter the command to boot from usb drive:
Switch:  boot usbflash0:imagefile.bin
Best regards
after boot from usbflash0 it struck in POST.
...done Initializing flashfs.
Checking for Bootloader upgrade..
Boot Loader upgrade not required (Stage 2)
FIPS: Flash Key Check : Begin
FIPS: Flash Key Check : End, Not Found, FIPS Mode Not Enabled
POST: MA BIST : Begin
POST: MA BIST : End, Status Passed
POST: TCAM BIST : Begin
POST: TCAM BIST : End, Status Passed
POST: ACT2 Authentication : Begin
POST: ACT2 Authentication : End, Status Passed
extracting front_end/front_end_ucode_info (43 bytes)
Software version is different so extracting
the whole bundle
extracting ucode_info (76 bytes)
front_end/ (directory)
extracting front_end/fe_type_9 (80781 bytes)
Front-end Microcode IMG MGR: Installed 1 image(s) in cache:
Front-end Microcode IMG MGR: found microcode images for 1 devices.
Image for front-end 0: flash:/front_end_ucode_cache/ucode.0
Front-end Microcode IMG MGR: Preparing to program device microcode...
Front-end Microcode IMG MGR: Preparing to program device[0]...28704 bytes.
Front-end Microcode IMG MGR: Programming device 0...rrrrrrwssssssss
% Front-end Microcode IMG MGR: address 0, PROGRAM failed
% Front-end Microcode IMG MGR: unable to program device: 0
% Front-end Microcode IMG MGR: malformed microcode cache
% Front-end Microcode IMG MGR: address 0, PROGRAM failed​
Raise a TAC Case and RMA the switch.
This could very well be CSCvf24186.
Leo Laohoo
If the switch is in ROMMON, post the complete output to the command "dir".
I want to determine if the 2960X is a counterfeit or not.  Counterfeit 2960X can only boot a certain IOS version, usually EX3, EX4 or EX5, and any version will fail software authentication.
switch: dir
List of filesystems currently registered:
bs[1]: (read-only)
flash[9]: (read-write)
xmodem[10]: (read-only)
null[11]: (read-write)
tftp[12]: (read-only)
switch:
after flash_init
switch: dir flash:
Directory of flash:/
3 -rwx 24559616 <date> c2960x-universalk9-mz.152-4.E1.bin
95143K bytes available (24178K bytes used)
switch:
Where is the old IOS file?
I deleted the old flash file aslo..
Delete flash
it was loading corrupted image file even i delete from flash
..done Initializing Flash.
Loading "flash:c2960x-universalk9-mz.152-7.E9/c2960x-universalk9-mz.152-7.E9.bin "...flash:c2960x-universalk9-mz.152-7.E9/c2960x-universalk9-mz.152-7.E9.bin: no such file or directory
Error loading "flash:c2960x-universalk9-mz.152-7.E9/c2960x-universalk9-mz.152-7. E9.bin"
Interrupt within 5 seconds to abort boot process.
Loading "flash:/c2960x-universalk9-mz.152-4.E1.bin"...Verifying image flash:/c29 60x-universalk9-mz.152-4.E1.bin................................................. ................................................................................
What IOS version did this switch originally came with?
original IOS before it corrupt was : c2960x-universalk9-mz.152-4.E1.bin
while software update via HTTP it corrupts and switch get struck, so i delete the original flash (all) and reinitialize with  flash:c2960x-universalk9-mz.152-7.E9 but not succeed. then again download the c2960x-universalk9-mz.152-4.E1.bin and switch:boot flash: c2960x-universalk9-mz.152-4.E1.bin
Console into the switch and reboot.
Post the entire boot-up process.
