cisco 9200 question
heyjunsun
hello
This time, at our company new switch buy
I changed it from 2960 switch to 9200 model
The only advantages I know are two power supplies, the WEBUI.
Other than these, is there a web address that explains the advantages or functions that 2900 doesn't have?
Leo Laohoo
Read the Release Notes for the 2960 and the 9200 to see the difference between the two.
What is the current 2960 configured to do?  Layer 2 switching only?  Dot1X?  Automation?
2960 is purely a simple layer 2 switch.  If the business use is purely that, a Layer 2 switch only, and the business use does not require automation or SD Access or DNAC, then 9200/9300 is a massive overkill.
The best layer 2 replacement for the entire 2960G/S/X/XR is the Catalyst 1000.
NOTE:  I would not recommend Catalyst 1200 and 1300 because these are SMB switches "promoted" to Catalyst portfolio and their behaviour is not at par with "classic" IOS.
hello
I only use it as a Layer and only access-list.
