C2960x Stack and switchport config change. Speed slow down in one switch
d.leung01
I have 1 x c2960S and 3 x 2960X stacking together.
All switches have the SDM preference at lanbase and same IOS version.
The stack port-speed at 10 for every switches.
I have modify the switch number and the priority of each switch.
The C2960S is the master switch.
I have install the switch one by one.
When I stack the third switch to the first and second switch.
The configuration of the switchport have change by they self.
2 lights have be added automatically to the configuration of the switchport on (second switch and third switch only) at the follow:
 power inline auto max 15400
 no power efficient-ethernet
After I have stacking all 4 switchs together.
Some user say the speed is slow.
Can somebody help me.
13 Replies 13
jhager001
Those two commands only have to deal with PoE. It wouldn't have anything to do with slowness. Have you tried to get your users to perform a speedtest, one that's having "slowness issues" and one that seems to be fine? compare that.
Unfortunately I get this excuse from users all the time, but they can never be specific on what is slow, if its an application their accessing, web based traffic, etc, etc
Soo for the two extra command. Should I take it off and how?
The frist command set the power inline to 15400 max. But the second "no power efficient-ethernet" what this command do?
The user connect to the second switch hasn't problem. But the user connect to the third switch have problem to access to the internal server connect to the fourth switch.
They aren't affecting anything, if you do 'show power inline' you can see what ports are currently pulling power from the switch since at least one of those switches are PoE (power over ethernet) able.
All switches are stacked together so there shouldn't be an issue there. Is it just the internal server they are having connection issues with? or all traffic? I would start with the laptop and assure they are actually connecting to your network and pulling a valid IP address for your network. Check the port configuration to make sure there's not anything that shouldn't be there.
Possible to show a running config for your stack?
please show me what you get when you type 'show switch'
Switch/Stack Mac Address : 64ae.0c7a.9680
                                           H/W   Current
Switch#  Role   Mac Address     Priority Version  State
*1       Master 64ae.0c7a.9680     14     1       Ready
 2       Member 8890.8d00.ec00     12     4       Ready
 3       Member 40a6.e89d.d380     10     4       Ready
 4       Member 8890.8d29.4680     9      4       Ready
Perfect, I would start at the problem end point, or get a testing computer and plug into the same switch that seems to be having the issue, attempt to perform a traceroute from the computer to the internal server and see where it stops, or if it indeed makes it all the way through. If they are gigabit ports, you can do a TDR test on the port itself to see if it may be a faulty patch cable as well.
I'm out of office. I can only test on tuesday.
All the network patch core were new.
I have testing some connection:
Connection to an server with the 10/100 interface.
Interface Speed Local pair Pair length        Remote pair Pair status
Gi1/0/1   100M  Pair A     4    +/- 0  meters Pair B      Normal
                         Pair B     5    +/- 0  meters Pair A      Normal
                         Pair C     4    +/- 1  meters Pair C      Short
                         Pair D     4    +/- 1  meters Pair D      Short
Connection to an 3Com switch with the 10/100 interface.
Gi1/0/23  100M  Pair A     29   +/- 0  meters Pair B      Normal
                           Pair B     29   +/- 0  meters Pair A      Normal
                           Pair C     29   +/- 1  meters Pair C      Short
                           Pair D     29   +/- 1  meters Pair D      Short
Connection trunk to an C3560v2 10/100 POE.
Gi1/0/24  100M  Pair A     0    +/- 0  meters Pair B      Normal
                          Pair B     0    +/- 0  meters Pair A      Normal
                          Pair C     0    +/- 1  meters Pair C      Short
                          Pair D     0    +/- 1  meters Pair D      Short
Connection to an Cisco IP phone 7911 10/100 interface.
Gi1/0/10  auto  Pair A     24   +/- 0  meters Pair B      Normal
                         Pair B     23   +/- 0  meters Pair A      Normal
                         Pair C     23   +/- 1  meters Pair C      Short/Crosstalk
                         Pair D     23   +/- 1  meters Pair D      Short/Crosstalk
I found this, sounds like it's in reference to the issue.
https://tools.cisco.com/bugsearch/bug/CSCun35096/?referring_site=bugquickviewredir
you can test a few ports with 'power efficient-ethernet auto' and see if you get any different results?
I have try to set 'power efficient-ethernet auto' but this don't help.
But the way, can be there some bug with the QOS? Because I realise all the workstations have problems. there all have an ip phone connect between the switch and the computer. We are using the 7942G and 7911G ip phone.
Do you have the option to open a TAC case? All the PoE is doing is providing power to your phones, it shouldn't have any effect on the data transfer to your laptop/pc.
We have Smartnet for the material failed only. I hav see this today.
http://www.gossamer-threads.com/lists/cisco/nsp/173830
They take about the qos. And I have the OutDiscards problem.
=~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2015.09.09 11:17:17 =~=~=~=~=~=~=~=~=~=~=~=
C
*             THIS SERVICE IS FOR AUTHORIZED USERS ONLY                *
* WARNING:  It is a criminal offense to:                               *
*           1. Obtain access to data without authority.                *
*           2. Damage, delete, alter or edit data without authority.   *
Using keyboard-interactive authentication.
BLEUTECHSW03#sh run
Building configuration...
Current configuration : 60239 bytes
! Last configuration change at 12:50:34 EDT Wed Aug 26 2015 by bleutech
! NVRAM config last updated at 12:50:39 EDT Wed Aug 26 2015 by bleutech
version 15.0
no service pad
hostname B
boot-start-marker
boot-end-marker
username
username
username
username
aaa new-model
aaa authentication login CONSOLE local
aaa authentication login VTY local
aaa session-id common
clock timezone EST -5 0
clock summer-time EDT recurring
switch 1 provision ws-c2960s-24ps-l
switch 2 provision ws-c2960x-48fps-l
switch 3 provision ws-c2960x-48fps-l
switch 4 provision ws-c2960x-48fps-l
ip routing
ip name-server 8.8.8.8
ip name-server 8.8.4.4
vtp mode transparent
mls qos map policed-dscp  0 10 18 24 46 to 8
mls qos map cos-dscp 0 8 16 24 32 46 48 56
mls qos srr-queue output cos-map queue 1 threshold 3 4 5
mls qos srr-queue output cos-map queue 2 threshold 1 2
mls qos srr-queue output cos-map queue 2 threshold 2 3
mls qos srr-queue output cos-map queue 2 threshold 3 6 7
mls qos srr-queue output cos-map queue 3 threshold 3 0
mls qos srr-queue output cos-map queue 4 threshold 3 1
mls qos srr-queue output dscp-map queue 1 threshold 3 32 33 40 41 42 43 44 45
mls qos srr-queue output dscp-map queue 1 threshold 3 46 47
mls qos srr-queue output dscp-map queue 2 threshold 1 16 17 18 19 20 21 22 23
mls qos srr-queue output dscp-map queue 2 threshold 1 26 27 28 29 30 31 34 35
mls qos srr-queue output dscp-map queue 2 threshold 1 36 37 38 39
mls qos srr-queue output dscp-map queue 2 threshold 2 24
mls qos srr-queue output dscp-map queue 2 threshold 3 48 49 50 51 52 53 54 55
mls qos srr-queue output dscp-map queue 2 threshold 3 56 57 58 59 60 61 62 63
mls qos srr-queue output dscp-map queue 3 threshold 3 0 1 2 3 4 5 6 7
mls qos srr-queue output dscp-map queue 4 threshold 1 8 9 11 13 15
mls qos srr-queue output dscp-map queue 4 threshold 2 10 12 14
mls qos queue-set output 1 threshold 1 100 100 50 200
mls qos queue-set output 1 threshold 2 125 125 100 400
mls qos queue-set output 1 threshold 3 100 100 100 400
mls qos queue-set output 1 threshold 4 60 150 50 200
mls qos queue-set output 1 buffers 15 25 40 20
mls qos
crypto pki trustpoint TP-self-signed-209360512
 enrollment selfsigned
 subject-name cn=IOS-Self-Signed-Certificate-209360512
 revocation-check none
 rsakeypair TP-self-signed-209360512
crypto pki certificate chain TP-self-signed-209360512
 certificate self-signed 01
  30820229 30820192 A0030201 02020101 300D0609 2A864886 F70D0101 05050030
  30312E30 2C060355 04031325 494F532D 53656C66 2D536967 6E65642D 43657274
  69666963 6174652D 32303933 36303531 32301E17 0D313130 33333030 31323932
  375A170D 32303031 30313030 30303030 5A303031 2E302C06 03550403 1325494F
  532D5365 6C662D53 69676E65 642D4365 72746966 69636174 652D3230 39333630
  35313230 819F300D 06092A86 4886F70D 01010105 0003818D 00308189 02818100
  9C760571 8AF81D46 E9928BC4 CFD6F63A EBA6DC00 E9CB56B4 C549C7E3 CE475615
  C87D1C5D F17BBC07 BCB6EE07 9447C439 F3816E86 0A326372 264821A8 E3B9DC5C
  64312C7E 293C2EFB 655ED9EB 4500B267 0F65D524 907E69FE 384E1F60 3244D197
  BABAB3D6 28BD67F0 FE5F24FE E30CB498 EBD3A003 946C731A 119F3122 799D430D
  02030100 01A35330 51300F06 03551D13 0101FF04 05300301 01FF301F 0603551D
  23041830 16801497 231D43CF 272E3DAD 6262F39C CA588405 294EA130 1D060355
  1D0E0416 04149723 1D43CF27 2E3DAD62 62F39CCA 58840529 4EA1300D 06092A86
  4886F70D 01010505 00038181 006DA067 C8D6D1AA 09851202 609FEB99 BF0D0F23
  A35EBD2A FFDAF00F 4DF1CEFC F901E08B F9A0F2E6 4B1EC654 3B524DE1 17711CD6
  92BC6F91 30B96028 42B6EC9A 804A6FC3 87F775F5 B2EB01DB 5DF62143 DAACF97E
  A11CC6A6 BED9D9EF 14DDADFC 25ECB9EB 2750D1B5 19520EEB AD62C719 305DBD17
  E3BE5EB4 C4FDFC7E DDD17E70 7F
  quit
spanning-tree mode pvst
vlan internal allocation policy ascending
vlan 2
 name Voice
vlan 3
 name GUEST
vlan 4
 name PUBLIC
class-map match-all AUTOQOS_VOIP_DATA_CLASS
  match ip dscp ef
class-map match-all AUTOQOS_DEFAULT_CLASS
  match access-group name AUTOQOS-ACL-DEFAULT
class-map match-all AUTOQOS_VOIP_SIGNAL_CLASS
  match ip dscp cs3
policy-map AUTOQOS-SRND4-CISCOPHONE-POLICY
 class AUTOQOS_VOIP_DATA_CLASS
   set dscp ef
  police 128000 8000 exceed-action policed-dscp-transmit
 class AUTOQOS_VOIP_SIGNAL_CLASS
   set dscp cs3
  police 32000 8000 exceed-action policed-dscp-transmit
 class AUTOQOS_DEFAULT_CLASS
   set dscp default
  police 10000000 8000 exceed-action policed-dscp-transmit
interface FastEthernet0
 no ip address
 no ip route-cache
interface GigabitEthernet1/0/1
 switchport mode access
 switchport voice vlan 2
 srr-queue bandwidth share 1 30 35 5
 priority-queue out
 mls qos trust device cisco-phone
 mls qos trust cos
 spanning-tree portfast
 spanning-tree bpduguard enable
 service-policy input AUTOQOS-SRND4-CISCOPHONE-POLICY
interface GigabitEthernet1/0/2
 priority-queue out
 mls qos trust cos
interface GigabitEthernet1/0/3
 priority-queue out
 mls qos trust cos
interface GigabitEthernet1/0/4
 priority-queue out
 mls qos trust cos
interface GigabitEthernet1/0/5
 priority-queue out
 mls qos trust cos
interface GigabitEthernet1/0/6
 priority-queue out
 mls qos trust cos
interface GigabitEthernet1/0/7
 priority-queue out
 mls qos trust cos
interface GigabitEthernet1/0/8
 priority-queue out
 mls qos trust cos
interface GigabitEthernet1/0/9
 priority-queue out
 mls qos trust cos
interface GigabitEthernet1/0/10
 priority-queue out
 mls qos trust cos
interface GigabitEthernet1/0/11
 switchport mode trunk
 priority-queue out
 mls qos trust cos
 spanning-tree bpduguard disable
interface GigabitEthernet1/0/12
 priority-queue out
 mls qos trust cos
interface GigabitEthernet1/0/13
 priority-queue out
 mls qos trust cos
interface GigabitEthernet1/0/14
 priority-queue out
 mls qos trust cos
interface GigabitEthernet1/0/15
 priority-queue out
 mls qos trust cos
 auto qos trust
interface GigabitEthernet1/0/16
 priority-queue out
 mls qos trust cos
interface GigabitEthernet1/0/17
 priority-queue out
 mls qos trust cos
interface GigabitEthernet1/0/18
 priority-queue out
 mls qos trust cos
interface GigabitEthernet1/0/19
 priority-queue out
 mls qos trust cos
interface GigabitEthernet1/0/20
 priority-queue out
 mls qos trust cos
interface GigabitEthernet1/0/21
 priority-queue out
 mls qos trust cos
interface GigabitEthernet1/0/22
 priority-queue out
 mls qos trust cos
interface GigabitEthernet1/0/23
 priority-queue out
 mls qos trust cos
 auto qos trust
interface GigabitEthernet1/0/24
 priority-queue out
 mls qos trust cos
 auto qos trust
interface GigabitEthernet1/0/25
 shutdown
interface GigabitEthernet1/0/26
 shutdown
interface GigabitEthernet1/0/27
 shutdown
interface GigabitEthernet1/0/28
 shutdown
interface GigabitEthernet2/0/1
 priority-queue out
 mls qos trust cos
interface GigabitEthernet2/0/2
 priority-queue out
 mls qos trust cos
interface GigabitEthernet2/0/3
 priority-queue out
 mls qos trust cos
interface GigabitEthernet2/0/4
 priority-queue out
 mls qos trust cos
interface GigabitEthernet2/0/5
 priority-queue out
 mls qos trust cos
interface GigabitEthernet2/0/6
 priority-queue out
 mls qos trust cos
interface GigabitEthernet2/0/7
 priority-queue out
 mls qos trust cos
interface GigabitEthernet2/0/8
 priority-queue out
 mls qos trust cos
interface GigabitEthernet2/0/9
 priority-queue out
 mls qos trust cos
interface GigabitEthernet2/0/10
 priority-queue out
 mls qos trust cos
interface GigabitEthernet2/0/11
 priority-queue out
 mls qos trust cos
interface GigabitEthernet2/0/12
 priority-queue out
 mls qos trust cos
interface GigabitEthernet2/0/13
 priority-queue out
 mls qos trust cos
interface GigabitEthernet2/0/14
 priority-queue out
 mls qos trust cos
interface GigabitEthernet2/0/15
 priority-queue out
 mls qos trust cos
interface GigabitEthernet2/0/16
 priority-queue out
 mls qos trust cos
interface GigabitEthernet2/0/17
 priority-queue out
 mls qos trust cos
interface GigabitEthernet2/0/18
 priority-queue out
 mls qos trust cos
interface GigabitEthernet2/0/19
 priority-queue out
 mls qos trust cos
interface GigabitEthernet2/0/20
 priority-queue out
 mls qos trust cos
interface GigabitEthernet2/0/21
 priority-queue out
 mls qos trust cos
interface GigabitEthernet2/0/22
 priority-queue out
 mls qos trust cos
interface GigabitEthernet2/0/23
 priority-queue out
 mls qos trust cos
interface GigabitEthernet2/0/24
 priority-queue out
 mls qos trust cos
interface GigabitEthernet2/0/25
 priority-queue out
 mls qos trust cos
interface GigabitEthernet2/0/26
 priority-queue out
 mls qos trust cos
interface GigabitEthernet2/0/27
 priority-queue out
 mls qos trust cos
interface GigabitEthernet2/0/28
 priority-queue out
 mls qos trust cos
interface GigabitEthernet2/0/29
 priority-queue out
 mls qos trust cos
interface GigabitEthernet2/0/30
 priority-queue out
 mls qos trust cos
interface GigabitEthernet2/0/31
 priority-queue out
 mls qos trust cos
interface GigabitEthernet2/0/32
 priority-queue out
 mls qos trust cos
interface GigabitEthernet2/0/33
 priority-queue out
 mls qos trust cos
interface GigabitEthernet2/0/34
 priority-queue out
 mls qos trust cos
interface GigabitEthernet2/0/35
 priority-queue out
 mls qos trust cos
interface GigabitEthernet2/0/36
 priority-queue out
 mls qos trust cos
interface GigabitEthernet2/0/37
 priority-queue out
 mls qos trust cos
interface GigabitEthernet2/0/38
 priority-queue out
 mls qos trust cos
interface GigabitEthernet2/0/39
 priority-queue out
 mls qos trust cos
interface GigabitEthernet2/0/40
 priority-queue out
 mls qos trust cos
interface GigabitEthernet2/0/41
 priority-queue out
 mls qos trust cos
interface GigabitEthernet2/0/42
 priority-queue out
 mls qos trust cos
interface GigabitEthernet2/0/43
 priority-queue out
 mls qos trust cos
interface GigabitEthernet2/0/44
 priority-queue out
 mls qos trust cos
interface GigabitEthernet2/0/45
 priority-queue out
 mls qos trust cos
interface GigabitEthernet2/0/46
 priority-queue out
 mls qos trust cos
interface GigabitEthernet2/0/47
interface GigabitEthernet2/0/48
interface GigabitEthernet2/0/49
 shutdown
interface GigabitEthernet2/0/50
 shutdown
interface GigabitEthernet2/0/51
 shutdown
interface GigabitEthernet2/0/52
 shutdown
interface GigabitEthernet3/0/1
 priority-queue out
 mls qos trust cos
interface GigabitEthernet3/0/2
 priority-queue out
 mls qos trust cos
interface GigabitEthernet3/0/3
 priority-queue out
 mls qos trust cos
interface GigabitEthernet3/0/4
 priority-queue out
 mls qos trust cos
interface GigabitEthernet3/0/5
 priority-queue out
 mls qos trust cos
interface GigabitEthernet3/0/6
 priority-queue out
 mls qos trust cos
interface GigabitEthernet3/0/7
 priority-queue out
 mls qos trust cos
interface GigabitEthernet3/0/8
 priority-queue out
 mls qos trust cos
interface GigabitEthernet3/0/9
 priority-queue out
 mls qos trust cos
interface GigabitEthernet3/0/10
 priority-queue out
 mls qos trust cos
interface GigabitEthernet3/0/11
 priority-queue out
 mls qos trust cos
interface GigabitEthernet3/0/12
 priority-queue out
 mls qos trust cos
interface GigabitEthernet3/0/13
 priority-queue out
 mls qos trust cos
interface GigabitEthernet3/0/14
 priority-queue out
 mls qos trust cos
interface GigabitEthernet3/0/15
 priority-queue out
 mls qos trust cos
interface GigabitEthernet3/0/16
 priority-queue out
 mls qos trust cos
interface GigabitEthernet3/0/17
 priority-queue out
 mls qos trust cos
interface GigabitEthernet3/0/18
 priority-queue out
 mls qos trust cos
interface GigabitEthernet3/0/19
 priority-queue out
 mls qos trust cos
interface GigabitEthernet3/0/20
 priority-queue out
 mls qos trust cos
interface GigabitEthernet3/0/21
 priority-queue out
 mls qos trust cos
interface GigabitEthernet3/0/22
 priority-queue out
 mls qos trust cos
interface GigabitEthernet3/0/23
 priority-queue out
 mls qos trust cos
interface GigabitEthernet3/0/24
 priority-queue out
 mls qos trust cos
interface GigabitEthernet3/0/25
 priority-queue out
 mls qos trust cos
interface GigabitEthernet3/0/26
 priority-queue out
 mls qos trust cos
interface GigabitEthernet3/0/27
 priority-queue out
 mls qos trust cos
interface GigabitEthernet3/0/28
 priority-queue out
 mls qos trust cos
interface GigabitEthernet3/0/29
 priority-queue out
 mls qos trust cos
interface GigabitEthernet3/0/30
 priority-queue out
 mls qos trust cos
interface GigabitEthernet3/0/31
 priority-queue out
 mls qos trust cos
interface GigabitEthernet3/0/32
 priority-queue out
 mls qos trust cos
interface GigabitEthernet3/0/33
 priority-queue out
 mls qos trust cos
interface GigabitEthernet3/0/34
 priority-queue out
 mls qos trust cos
interface GigabitEthernet3/0/35
 priority-queue out
 mls qos trust cos
interface GigabitEthernet3/0/36
 priority-queue out
 mls qos trust cos
interface GigabitEthernet3/0/37
 priority-queue out
 mls qos trust cos
interface GigabitEthernet3/0/38
 priority-queue out
 mls qos trust cos
interface GigabitEthernet3/0/39
 priority-queue out
 mls qos trust cos
interface GigabitEthernet3/0/40
 priority-queue out
 mls qos trust cos
interface GigabitEthernet3/0/41
 priority-queue out
 mls qos trust cos
interface GigabitEthernet3/0/42
 priority-queue out
 mls qos trust cos
interface GigabitEthernet3/0/43
 priority-queue out
 mls qos trust cos
interface GigabitEthernet3/0/44
 priority-queue out
 mls qos trust cos
interface GigabitEthernet3/0/45
 priority-queue out
 mls qos trust cos
 auto qos voip cisco-phone
interface GigabitEthernet3/0/46
 priority-queue out
 mls qos trust cos
interface GigabitEthernet3/0/47
 priority-queue out
 mls qos trust cos
 auto qos trust
interface GigabitEthernet3/0/48
 priority-queue out
 mls qos trust cos
 auto qos trust
interface GigabitEthernet3/0/49
 shutdown
interface GigabitEthernet3/0/50
 shutdown
interface GigabitEthernet3/0/51
 shutdown
interface GigabitEthernet3/0/52
 shutdown
interface GigabitEthernet4/0/1
 priority-queue out
 mls qos trust cos
interface GigabitEthernet4/0/2
 priority-queue out
 mls qos trust cos
interface GigabitEthernet4/0/3
 priority-queue out
 mls qos trust cos
interface GigabitEthernet4/0/4
 power inline never
 priority-queue out
 mls qos trust cos
interface GigabitEthernet4/0/5
 priority-queue out
 mls qos trust cos
interface GigabitEthernet4/0/6
 priority-queue out
 mls qos trust cos
interface GigabitEthernet4/0/7
 priority-queue out
 mls qos trust cos
interface GigabitEthernet4/0/8
 priority-queue out
 mls qos trust cos
interface GigabitEthernet4/0/9
 priority-queue out
 mls qos trust cos
interface GigabitEthernet4/0/10
 priority-queue out
 mls qos trust cos
interface GigabitEthernet4/0/11
 priority-queue out
 mls qos trust cos
interface GigabitEthernet4/0/12
 priority-queue out
 mls qos trust cos
interface GigabitEthernet4/0/13
 priority-queue out
 mls qos trust cos
interface GigabitEthernet4/0/14
 priority-queue out
 mls qos trust cos
interface GigabitEthernet4/0/15
 priority-queue out
 mls qos trust cos
interface GigabitEthernet4/0/16
 priority-queue out
 mls qos trust cos
interface GigabitEthernet4/0/17
 priority-queue out
 mls qos trust cos
interface GigabitEthernet4/0/18
 priority-queue out
 mls qos trust cos
interface GigabitEthernet4/0/19
 priority-queue out
 mls qos trust cos
interface GigabitEthernet4/0/20
 priority-queue out
 mls qos trust cos
interface GigabitEthernet4/0/21
 priority-queue out
 mls qos trust cos
interface GigabitEthernet4/0/22
 priority-queue out
 mls qos trust cos
interface GigabitEthernet4/0/23
 priority-queue out
 mls qos trust cos
interface GigabitEthernet4/0/24
 priority-queue out
 mls qos trust cos
interface GigabitEthernet4/0/25
 priority-queue out
 mls qos trust cos
interface GigabitEthernet4/0/26
 priority-queue out
 mls qos trust cos
interface GigabitEthernet4/0/27
 priority-queue out
 mls qos trust cos
interface GigabitEthernet4/0/28
 priority-queue out
 mls qos trust cos
interface GigabitEthernet4/0/29
 priority-queue out
 mls qos trust cos
interface GigabitEthernet4/0/30
 priority-queue out
 mls qos trust cos
interface GigabitEthernet4/0/31
 priority-queue out
 mls qos trust cos
interface GigabitEthernet4/0/32
 priority-queue out
 mls qos trust cos
interface GigabitEthernet4/0/33
 priority-queue out
 mls qos trust cos
interface GigabitEthernet4/0/34
 priority-queue out
 mls qos trust cos
interface GigabitEthernet4/0/35
 priority-queue out
 mls qos trust cos
interface GigabitEthernet4/0/36
 priority-queue out
 mls qos trust cos
interface GigabitEthernet4/0/37
 priority-queue out
 mls qos trust cos
interface GigabitEthernet4/0/38
 priority-queue out
 mls qos trust cos
interface GigabitEthernet4/0/39
 priority-queue out
 mls qos trust cos
interface GigabitEthernet4/0/40
 priority-queue out
 mls qos trust cos
interface GigabitEthernet4/0/41
 priority-queue out
 mls qos trust cos
interface GigabitEthernet4/0/42
 priority-queue out
 mls qos trust cos
interface GigabitEthernet4/0/43
 priority-queue out
 mls qos trust cos
interface GigabitEthernet4/0/44
 priority-queue out
 mls qos trust cos
interface GigabitEthernet4/0/45
 priority-queue out
 mls qos trust cos
interface GigabitEthernet4/0/46
 priority-queue out
 mls qos trust cos
interface GigabitEthernet4/0/47
 priority-queue out
 mls qos trust cos
 auto qos trust
interface GigabitEthernet4/0/48
 priority-queue out
 mls qos trust cos
 auto qos trust
interface GigabitEthernet4/0/49
interface GigabitEthernet4/0/50
interface GigabitEthernet4/0/51
interface GigabitEthernet4/0/52
interface Vlan1
 ip address 172.16.226.x 255.255.255.0
interface Vlan2
 ip address 172.16.227.x 255.255.255.0 secondary
 ip address 172.24.227.x 255.255.255.0
interface Vlan3
 no ip address
interface Vlan4
 no ip address
ip default-gateway 172.16.226.x
no ip http server
ip http secure-server
ip route 0.0.0.0 0.0.0.0 172.16.226.x
ip access-list extended AUTOQOS-ACL-DEFAULT
 permit ip any any
snmp-server community public RO
banner login ^C
C
^C
line con 0
 login authentication CONSOLE
line vty 0 4
 privilege level 15
 login authentication VTY
 length 0
 transport input telnet ssh
line vty 5 15
 privilege level 15
ntp server 208.80.96.70
end
BLEUTECHSW03#exit
