Catalyst 3560 SYSTEM light on and Freeze
carlosrifel
Good Morning,
I have a Cisco Catalyst 3560 PoE-24 that when i turn on stay the SYSTEM light on green and i can't connect to the witch not even with serial cable. Please i need a Solution
InayathUlla Sharieff
HI,
Is that serial cable means console cable? If yes what do you see on the screen?
Can you try to break it in rommon and see if it responds there?
Rommon mode and recover method to be found in below link:-
http://www.cisco.com/c/en/us/support/docs/switches/catalyst-2950-series-switches/41845-192.html
Inayath
********Please do not forget to rate the post if helpfull********
Sorry yes is a console cable, I don't see anything. Don't have conection with the switch!
I tried to dit but it but doesn't respond.
Thanks for your answer
