C2960X Switch Weak MAC Algorithms
test52
Frequent Visitor
Frequent Visitor
We performed vulnerability scan on our C2960X switches and found the following message:
Checks the supported MAC algorithms (client-to-server and
  server-to-client) of the remote SSH server.
  Currently weak MAC algorithms are defined as the following:
  - MD5 based algorithms
  - 96-bit based algorithms
  - none algorithm
We saw that the output of MAC Algorithms in "show ip ssh" is hmac-sha1, hmac-sha1-96.
Is there firmware versions that support hmac-sha2 for C2960X switch? If not, should we remove hmac-sha1-96 from the list of MAC algorithms by the command "ip ssh server algorithm mac hmac-sha1"? Our current firmware version is 15.0(2a)EX5, model is WS-C2960X-24TS-L.
DanielP211
Hello!
I would definatly upgrade to the recommended version 15.2.7E9. Your version is very old. I cheched the version 15.2.7(E7) which I have and the supported algorithms for MAC are:
MAC Algorithms:hmac-sha2-256,hmac-sha2-512,hmac-sha1,hmac-sha1-96
BR
****Kindly rate all useful posts*****
