C3020 speed nonegociate issue ??
jjpeyrache
from configuration guide we can set
speed no negociate on C3020's SFP port
but i do no find this command see above
any comments welcomed
JYP
Cisco IOS Software, CBS30X0 Software (CBS30X0-IPBASE-M), Version 12.2(50)SE, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2009 by Cisco Systems, Inc.
Compiled Sat 28-Feb-09 00:18 by weiliu
Image text-base: 0x00003000, data-base: 0x01540000
GigabitEthernet0/20 is up, line protocol is up (connected)
Hardware is Gigabit Ethernet, address is 001f.9d7c.f914 (bia 001f.9d7c.f914)
MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec,
Keepalive not set
Full-duplex, 1000Mb/s, link type is auto, media type is 1000BaseSX SFP
Switch#conf t
Enter configuration commands, one per line. End with CNTL/Z.
Switch(config)#inter
Switch(config)#interface gi
Switch(config)#interface gigabitEthernet 0/20
Switch(config-if)#s?
service-policy shutdown small-frame snmp
source spanning-tree srr-queue storm-control
switchport
Switch(config-if)#s
tstanik
Level 5
Level 5
The 1000BASE-SX SFP module ports support the nonegotiate keyword in the speed interface configuration command. Duplex options are not supported.
If you are connected to a device that does not support autonegotiation, you can configure speed on copper SFP module ports; however, you can only configure fiber SFP module ports to not negotiate (nonegotiate).
When configuring an interface speed and duplex mode, note these guidelines.
http://www.cisco.com/en/US/docs/switches/blades/3020/software/release/12.2_25_sef1/configuration/guide/swint.html#wp1080632
