C3650 mgmt interface won't do NTP....
abatson
I've got a healthy  C3650 switch, whose management interface is the 'gi0/0' interface on the front of the machine.  The switch will send syslog on this interface just fine, and it's listening on SSH on this interface too.   DNS works too, because I can resolve hostnames.   However, "show ntp assoc"    just sits at the "**INIT**"  stage, and never progresses.    I know that gi0/0 is seperated from the main routing engine of the switch (by design, I know).   What am I missing?   I've configured tons of switches to do NTP before, but this is my first switch where the mgmt interface is seperated from the main routing engine..  Other devices on my network are successfully using "0.pool.ntp.org", so I know its not an availability issue....   My gi0/0 is connected to a firewall that allows Internet Access (where other devices route their traffic that work just fine)    Config below...
=~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2015.05.28 17:31:32 =~=~=~=~=~=~=~=~=~=~=~=
External-Switch#
External-Switch#show run
Building configuration...
Current configuration : 5020 bytes
! Last configuration change at 21:28:09 UTC Thu May 28 2015 by xxxxxxxxxxxx
version 15.0
no service pad
service compress-config
hostname External-Switch
boot-start-marker
boot-end-marker
vrf definition Mgmt-vrf
 address-family ipv4
 exit-address-family
 address-family ipv6
 exit-address-family
enable password xxxxxxxxxxxxxxxxx
username xxxxxx password 0 xxxxxxxxx
username xxxxxxx password 0 xxxxxxxxx
aaa new-model
aaa session-id common
switch 1 provision ws-c3650-24ps
ip domain-name nowhere.com
ip name-server <IP of our DNS Server>
crypto pki trustpoint TP-self-signed-1007421793
 enrollment selfsigned
 subject-name cn=IOS-Self-Signed-Certificate-1007421793
 revocation-check none
 rsakeypair TP-self-signed-1007421793
crypto pki certificate chain TP-self-signed-1007421793
 certificate self-signed 01
xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
Cert went here......
      quit
diagnostic bootup level minimal
spanning-tree mode pvst
redundancy
 mode sso
ip ssh version 2
class-map match-any non-client-nrt-class
  match non-client-nrt
interface GigabitEthernet0/0
 vrf forwarding Mgmt-vrf
 ip address 192.168.77.250 255.255.255.0
 negotiation auto
interface GigabitEthernet1/0/1
 description Ethernet From ISP
 switchport access vlan 999
 switchport mode access
 speed 100
 duplex full
 spanning-tree portfast
interface GigabitEthernet1/0/2
interface GigabitEthernet1/0/3
interface GigabitEthernet1/0/4
interface GigabitEthernet1/0/5
interface GigabitEthernet1/0/6
interface GigabitEthernet1/0/7
 description mirror port for 1/0/1
 speed 1000
 duplex full
interface GigabitEthernet1/0/8
interface GigabitEthernet1/0/9
xxxxxxxlots of empty interfaces....
interface GigabitEthernet1/1/4
interface Vlan1
 no ip address
 shutdown
ip default-gateway 192.168.77.1
no ip http server
ip http authentication local
ip http secure-server
ip route vrf Mgmt-vrf 0.0.0.0 0.0.0.0 192.168.77.1
logging facility local0
logging host 192.168.77.246
no cdp run
no cdp tlv location
no cdp tlv app
line con 0
 stopbits 1
line aux 0
 stopbits 1
line vty 0 4
 transport input ssh
line vty 5
 transport input ssh
line vty 6 15
monitor session 7 source interface Gi1/0/1
monitor session 7 destination interface Gi1/0/7
ntp server 0.pool.ntp.org source GigabitEthernet0/0
wsma agent exec
 profile httplistener
 profile httpslistener
wsma agent config
wsma agent filesys
wsma agent notify
wsma profile listener httplistener
 transport http
wsma profile listener httpslistener
 transport https
ap group default-group
end
External-Switch#
External-Switch#
External-Switch#
5 Replies 5
Reza Sharifi
Your config looks correct.
Question, why do you have
command in addition to the default route in the mgmt vrf?
you only need
since the switch is layer-2
I saw both methods of supplying default gateway info, and I was starting to grasp at straws to get this to work.
DNS won't work unless I have "ip default-gateway" defined.   I've tried NTP with and without that config item, and still no dice on NTP.   Oddly enough it shows I can't get a MAC for my default gatway:
Protocol       Address                 Age  (min)         Hardware Addr          Type          Interface
Internet          192.168.77.1                    0             Incomplete                 ARPA
this gi0/0 for management is magic!  I just verified that I'm seeing syslog from this switch, but I have no MAC addresses in the ARP table.   My syslog server is on the same layer-3 network as my mgmt interface, but yet I can't ping it (but syslog makes it just fine).   SSH is also listening on this port just fine & can SSH just fine.
Are we sure there's not some addn'l ACL that I have to adjust, to allow NTP traffic to exit this interface?
I liked the idea of the mgmt interface being seperated from all the other traffic on the switch, but I guess if I need to, i'll have to create a "vlan 77"  *interface*  on the switch, and manage it that way....
johncheung09
Hi abatson,
NTP server configure should be as below if via management port:
Switch(config)# ntp server vrf Mgmt-vrf <IP Address>
If using FQDN, DNS server define as:
Switch(config)# ip name-server vrf Mgmt-vrf <DNS server IP Address>
then:
Switch(config)# ntp server vrf Mgmt-vrf <FQDN>
John Cheung
