C3750 not booting
jithugeorge259
Hi all,
c3750 not completing booting
File "flash:/c3750-ipservicesk9-mz.122-55.SE11.bin" uncompressed and installed, entry point: 0x1000000
executing...
Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
cisco Systems, Inc.
170 West Tasman Drive
San Jose, California 95134-1706
Cisco IOS Software, C3750 Software (C3750-IPSERVICESK9-M), Version 12.2(55)SE11, RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2016 by Cisco Systems, Inc.
Compiled Wed 17-Aug-16 13:28 by prod_rel_team
Image text-base: 0x01000000, data-base: 0x02F00000
Initializing flashfs...
flashfs[1]: 210 files, 3 directories
flashfs[1]: 0 orphaned files, 0 orphaned directories
flashfs[1]: Total bytes: 15998976
flashfs[1]: Bytes used: 15998976
flashfs[1]: Bytes available: 0
flashfs[1]: flashfs fsck took 2 seconds.
flashfs[1]: Initialization complete....done Initializing flashfs.
Checking for Bootloader upgrade.. not needed
POST: CPU MIC register Tests : Begin
POST: CPU MIC register Tests : End, Status Passed
POST: PortASIC Memory Tests : Begin
POST: PortASIC Memory Tests : End, Status Passed
POST: CPU MIC interface Loopback Tests : Begin
POST: CPU MIC interface Loopback Tests : End, Status Passed
POST: PortASIC RingLoopback Tests : Begin
POST: PortASIC RingLoopback Tests : End, Status Passed
Waiting for Stack Master Election...
POST: Inline Power Controller Tests : Begin
POST: Inline Power Controller Tests : End, Status Passed
POST: PortASIC CAM Subsystem Tests : Begin
POST: PortASIC CAM Subsystem Tests : End, Status Passed
POST: No Cable found on stack port 1
POST: No Cable found on stack port 2
POST: PortASIC Stack Port Loopback Tests : Begin
POST: PortASIC Stack Port Loopback Tests : End, Status Passed
POST: PortASIC Port Loopback Tests : Begin
POST: PortASIC Port Loopback Tests : End, Status Passed
Election Complete
Switch 1 booting as Master
Waiting for Port download...Complete
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco WS-C3750-24P (PowerPC405) processor (revision J0) with 131072K bytes of memory.
Processor board ID CAT1026RLY3
Last reset from power-on
1 Virtual Ethernet interface
24 FastEthernet interfaces
2 Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
512K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address : 00:0A:B8:A1:FD:80
Motherboard assembly number : 73-9672-09
Power supply part number : 341-0029-05
Motherboard serial number : CAT102664PM
Power supply serial number : LIT102102XK
Model revision number : J0
Motherboard revision number : A0
Model number : WS-C3750-24PS-S
System serial number : CAT1026RLY3
Top Assembly Part Number : 800-25860-04
Top Assembly Revision Number : B0
Version ID : V05
CLEI Code Number : CNMV1K0CRD
Hardware Board Revision Number : 0x01
Switch Ports Model SW Version SW Image
* 1 26 WS-C3750-24P 12.2(55)SE11 C3750-IPSERVICESK9-M
% There may not be enough space available to collect the complete crashinfo
% It would be advisable to have 282836 bytes free space on flash:crashinfo
exiting from express setup mode...IP connections may be lost...
tried to remove delete files from flash, but it showing as there is no device available,...
please help
 Run dir falsh: and do an assessment on the file you have. Run show boot and see which IOS you are usimg. Your switch ir running out of space and you may have unsued IOs file on the flash. Idenfy and delete unecessary filés. Then reload the switch
