c3750 vlan filter' problem...
Kevin Wang
Community Member
What's wrong with the following configuration? I only want the hosts in the mac access list to communicate with each other, but it doesn't work, why? The test device is c3750.
mac access-list extended test-mac
 permit host aaaa.aaaa.aaaa host bbbb.bbbb.bbbb
 permit host bbbb.bbbb.bbbb host aaaa.aaaa.aaaa
 deny   any any
vlan access-map test-mac 10
 action forward
 match mac address test-mac
vlan access-map test-mac 20
 action drop
vlan filter test-mac vlan-list 1
5 Replies 5
acampbell
Hi Kevin,
I am assuming that you are saying this is not working because the
2 devices in the mac access list cannot ping each other etc.
What you need to remember is that in the 1st instance they need to find each other.
They need to ARP - ARP goes to the broadcast mac address.
Try changining your MAC access list as follows:-
no mac access-list extended test-mac
permit any any 0x0806 0x0000
permit any any lsap 0xAAAA 0x0000
deny any any
The 2 lines
permit any any 0x0806 0x0000 = THIS ALLOWS ARP
permit any any lsap 0xAAAA 0x0000 = THIS ALLOWS PVST+ TO ALLOW SPANNING TREE
Give it a go
Alex
Regards, Alex. Please rate useful posts.
The captured packets show that stp and arp work properly now,  but the two hosts still can't communicate with each other...
Kevin Wang
Community Member
I've changed the configuration as following:
 permit any any lsap 0x4242 0x0
 permit any any 0x010B 0x0
 deny   any any
ip access-list extended test-ip
 permit ip any any
 action forward
vlan access-map test-mac 15
 action forward
 match ip address test-ip
 action drop
Now, the two hosts can communicate with each other. It seems like the MAC access list doesn't work properly (I've checked it again and again, there is no typos), is it a bug?
Kevin,
I dont think this is a bug as such
When you read the config guides e.g.
12.2.55SE - Configuring Network Security with ACLs
http://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst3750/software/release/12-2_55_se/configuration/guide/scg3750/swacl.html
An ACL contains an ordered list of access control entries (ACEs). Each ACE specifies permit or deny and a set of conditions the packet must satisfy in order to match the ACE. The meaning of permit or deny depends on the context in which the ACL is used.
The switch supports IP ACLs and Ethernet (MAC) ACLs:
•IP ACLs filter IPv4 traffic, including TCP, User Datagram Protocol (UDP), Internet Group Management Protocol (IGMP), and Internet Control Message Protocol (ICMP).
•Ethernet ACLs filter non-IP traffic.
So because you are probably testing with IP (ICMP ping tracert etc) you need to invoke an IP access list
Other newer smaller switches like 2960 etc also say that MAC access lists are only for LAN-BASE licences
Alex
When a MAC ACE matched, shouldn't it take the 'action forward'?
When I apply the same MAC access list to a interface, it does work, only the hosts in the MAC ACL can communicate with each other, but when I apply it to a VLAN, it doesn't.
deny any any
interface FastEthernet1/0/2
mac access-group test-mac in
