C3850-12-S-S & C3850-24T-S licence issue
knaik99
I am going to stack one C3850-12-S-S & two * C3850-24T-S so I am going to use it as LAN core and Please let me know about licence that I have to buy to run IP base IOS on 3850 and also please let me know any other licence I have to order ---
balaji.bandi
StackWise-480 supports a mixed stack of any Catalyst 3850 models (48 ports 10/100/1000, 24 ports 10/100/1000, and 12/24 Ethernet SFP ports; see Figure 1).
You can mix the switches with different number of access ports (48, 24, and 12), different type of access ports (copper and fiber, PoE,
and non-PoE-capable), and different network modules. But all switches in one stack must have the same version of IOS XE and the same feature set license.
A mixed stack of LAN base switches with IP base or IP services is not supported.
Catalyst 3850 Series Switches with a LAN base feature set can only stack with other Catalyst 3850 Series LAN base switches. The same applies to IP base and IP services as well.
http://www.cisco.com/c/en/us/products/collateral/switches/catalyst-3850-series-switches/white-paper-c11-734429.html
BB
