06-17-2015 01:46 PM - edited 03-08-2019 12:36 AM
I need to purchase some C3850s or C3650s that will support Policy Based Routing.
I've reviewed the Cisco Feature Navigator
C3850 / Release 3.6.0E Universal IPBase / Image name cat3k_caa-universalk9.SPA.03.06.00.E.152-2.E.bin
The available features indicate Policy-Based Routing.
However, I've read the following which indicated that I need the IP Services license.
Policy-based routing (PBR) allows superior control by facilitating flow redirection regardless of the routing protocol configured. Virtual routing and forwarding (VRF)-Lite enables a service provider to support two or more VPNs, with overlapping IP addresses. The IP Services feature set is required.
I see two different answers to the question of PBR being supported with IPBase.
Can someone help me get this straight. I don't want to purchase the IPServices license if I don't have to.
Solved! Go to Solution.
06-17-2015 05:11 PM
PBR is supported with IP BASE. Please find the details below on the link:-
http://www.cisco.com/c/en/us/products/collateral/switches/catalyst-3850-series-switches/qa_c67-722110.html
Functions |
Layer 3 | RIP, EIGRP stub, OSPF for routed access, PBR, IPv4 & IPv6 EIGRP stub routing, WCCP, IPV6 uRPF, IPV6 PBR, VRRPv3, Policy Classification Engine, HSRP v6 |
06-17-2015 05:13 PM
And you need to run the Advanced template for PBR. (Show sdp prefer will give you that info)
(config)#sdm prefer advanced
06-17-2015 05:11 PM
Functions |
06-17-2015 05:13 PM
