C3850-NM-1G port does not light up
robert.meany1
I have a known working SFP and C3850-NM-1G, known working connection..  We recently installed the new 3850 switch as our core at one of our buildings to replace a 3750.  When connecting the SFP, I am not getting a connection light on the port.  We installed another identical 3850 switch, which I tried the module in and had the same issue.  There was a pre-existing 3850 switch of the same model, which I then tried the NM in and the port lights up fine.
The only difference I can think of between the pre-existing 3850 switch and the two newly installed ones is the pre-existing switch is running firmware 03.02.03SE while the new switches I upgraded the firmware to 03.06.06E to alleviate an issue with packets getting dropped during inter-vlan routing.
running-config on one of the non-working switches:
! Last configuration change at 20:11:32 EST Thu Mar 9 2017 by naugyadmin
! NVRAM config last updated at 20:11:33 EST Thu Mar 9 2017 by naugyadmin
version 15.2
no service pad
service password-encryption
service compress-config
service unsupported-transceiver
hostname wes-mdf-3850-01
boot-start-marker
boot system switch all flash:/running-packages.conf
boot-end-marker
vrf definition Mgmt-vrf
address-family ipv4
exit-address-family
address-family ipv6
exit-address-family
enable secret 5 $1$ySE6$LqxbH6KhiSf3TLAeGFZlk0
username naugyadmin privilege 15 password 7 13213F313B18073A727D6378
aaa new-model
aaa authorization exec default local
aaa authorization network default local
aaa session-id common
clock timezone EST -5 0
clock summer-time EDT recurring
switch 1 provision ws-c3850-48p
ip dhcp excluded-address 10.55.0.1 10.55.0.25
ip dhcp excluded-address 10.55.100.1 10.55.100.25
ip dhcp excluded-address 10.55.250.1 10.55.250.25
ip dhcp excluded-address 10.55.9.1 10.55.9.50
qos wireless-default-untrust
qos queue-softmax-multiplier 100
crypto pki trustpoint TP-self-signed-824874578
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-824874578
revocation-check none
rsakeypair TP-self-signed-824874578
crypto pki certificate chain TP-self-signed-824874578
certificate self-signed 02
30820245 308201AE A0030201 02020102 300D0609 2A864886 F70D0101 04050030
30312E30 2C060355 04031325 494F532D 53656C66 2D536967 6E65642D 43657274
69666963 6174652D 38323438 37343537 38301E17 0D313730 33303930 39353334
355A170D 32303031 30313030 30303030 5A303031 2E302C06 03550403 1325494F
532D5365 6C662D53 69676E65 642D4365 72746966 69636174 652D3832 34383734
35373830 819F300D 06092A86 4886F70D 01010105 0003818D 00308189 02818100
99E6F468 8CA161F7 18BAE579 0E0D6A91 5C86D7F1 8579FFB0 95F0D22E 381F614D
949410A6 12664956 70E9B6EF D7D0A217 4A5B11A5 B76DC9E1 D352545E 70DCB63F
801A3F53 A541C46E 81436DAD 2BDCE160 10789CCC 5151EFAB 7F03F77A 48EED0D6
45F1BA92 36DC5553 B11E0CBF 5E94E407 D5314981 FA705570 B51BDDC6 8F8ECC21
02030100 01A36F30 6D300F06 03551D13 0101FF04 05300301 01FF301A 0603551D
11041330 11820F77 65732D6D 64662D33 3835302D 3031301F 0603551D 23041830
16801419 C3FFCFD7 A9B6CD54 46BF7EEC 0D5580F5 82A49630 1D060355 1D0E0416
041419C3 FFCFD7A9 B6CD5446 BF7EEC0D 5580F582 A496300D 06092A86 4886F70D
01010405 00038181 0050C1B8 17B021A1 3020C925 41172E3A 22A572C2 9D96421B
ECF6B3DE 6F11D331 4C777C80 7B755543 E9A523E1 D4FA4C68 1D59EDFB 4239FD00
DF496247 BB2CC7E5 3F41612E E06CC723 AF74705D D1B0EC3B 0FFFB640 188BB2A5
162AF421 9C16F938 8BF91B8C F6A23299 A93D43E5 F4BFBAB5 5E6CB308 C148DAA8
486DC5D7 8679BA9B 55
quit
no errdisable detect cause gbic-invalid
diagnostic bootup level minimal
spanning-tree mode pvst
spanning-tree vlan 1-1024 priority 4096
hw-switch switch 1 logging onboard message level 3
redundancy
mode sso
class-map match-any non-client-nrt-class
interface GigabitEthernet0/0
vrf forwarding Mgmt-vrf
no ip address
no ip route-cache
negotiation auto
interface GigabitEthernet1/0/1
switchport access vlan 300
switchport mode access
snmp trap mac-notification change added
snmp trap mac-notification change removed
spanning-tree portfast
spanning-tree bpduguard enable
interface GigabitEthernet1/0/2
interface GigabitEthernet1/0/3
interface GigabitEthernet1/0/4
interface GigabitEthernet1/0/5
interface GigabitEthernet1/0/6
interface GigabitEthernet1/0/7
interface GigabitEthernet1/0/8
interface GigabitEthernet1/0/9
interface GigabitEthernet1/0/10
interface GigabitEthernet1/0/11
interface GigabitEthernet1/0/12
interface GigabitEthernet1/0/13
interface GigabitEthernet1/0/14
interface GigabitEthernet1/0/15
interface GigabitEthernet1/0/16
interface GigabitEthernet1/0/17
interface GigabitEthernet1/0/18
interface GigabitEthernet1/0/19
interface GigabitEthernet1/0/20
interface GigabitEthernet1/0/21
interface GigabitEthernet1/0/22
interface GigabitEthernet1/0/23
interface GigabitEthernet1/0/24
interface GigabitEthernet1/0/25
interface GigabitEthernet1/0/26
interface GigabitEthernet1/0/27
interface GigabitEthernet1/0/28
interface GigabitEthernet1/0/29
interface GigabitEthernet1/0/30
interface GigabitEthernet1/0/31
interface GigabitEthernet1/0/32
interface GigabitEthernet1/0/33
interface GigabitEthernet1/0/34
interface GigabitEthernet1/0/35
interface GigabitEthernet1/0/36
interface GigabitEthernet1/0/37
interface GigabitEthernet1/0/38
interface GigabitEthernet1/0/39
interface GigabitEthernet1/0/40
interface GigabitEthernet1/0/41
interface GigabitEthernet1/0/42
interface GigabitEthernet1/0/43
interface GigabitEthernet1/0/44
description < Comcast Edgewater >
switchport access vlan 309
interface GigabitEthernet1/0/45
description < Downlink >
switchport mode trunk
interface GigabitEthernet1/0/46
interface GigabitEthernet1/0/47
interface GigabitEthernet1/0/48
interface GigabitEthernet1/1/1
interface GigabitEthernet1/1/2
interface GigabitEthernet1/1/3
interface GigabitEthernet1/1/4
description < Link to High School - ATT >
switchport access vlan 903
switchport nonegotiate
interface TenGigabitEthernet1/1/1
interface TenGigabitEthernet1/1/2
interface TenGigabitEthernet1/1/3
interface TenGigabitEthernet1/1/4
interface Vlan1
no ip address
no ip route-cache
shutdown
interface Vlan200
ip address 10.55.200.13 255.255.255.0
no ip route-cache
ip default-gateway 10.55.200.1
ip forward-protocol nd
ip http server
ip http authentication aaa
ip http secure-server
access-list 50 permit 10.1.10.2
access-list 50 permit 10.100.20.29
access-list 50 deny any
snmp-server community ***** RO
snmp-server community ***** RW 50
snmp-server enable traps snmp coldstart warmstart
snmp-server enable traps license
snmp-server enable traps mac-notification change move threshold
snmp-server host 10.1.10.2 *****
snmp-server host 10.100.20.29 ******
line con 0
logging synchronous
stopbits 1
line aux 0
stopbits 1
line vty 0 4
transport input ssh
line vty 5 15
ntp server 10.100.20.2
wsma agent exec
profile httplistener
profile httpslistener
wsma agent config
wsma agent filesys
wsma agent notify
wsma profile listener httplistener
transport http
wsma profile listener httpslistener
transport https
ap dot11 24ghz rrm channel dca add 1
ap dot11 24ghz rrm channel dca add 6
ap dot11 24ghz rrm channel dca add 11
ap dot11 5ghz rrm channel dca add 36
ap dot11 5ghz rrm channel dca add 40
ap dot11 5ghz rrm channel dca add 44
ap dot11 5ghz rrm channel dca add 48
ap dot11 5ghz rrm channel dca add 52
ap dot11 5ghz rrm channel dca add 56
ap dot11 5ghz rrm channel dca add 60
ap dot11 5ghz rrm channel dca add 64
ap dot11 5ghz rrm channel dca add 149
ap dot11 5ghz rrm channel dca add 153
ap dot11 5ghz rrm channel dca add 157
ap dot11 5ghz rrm channel dca add 161
ap group default-group
end
I don't have output from sho inv because the NM is no longer installed, but when I did run it, it had detected the NM and the SFP correctly and said they were installed and running.  The ports were *not* in err-disable state.  It was just not detecting that the fiber was connected for some reason...
I tested the SFP in other ports as well, that were *not* configured with nonegotiate and that made no difference.
Julio E. Moisa
It could be a compatibility problem, please verify your if your module is compatible with your switch, also check the internal pins in order to see if they are not a hardware damage:
Table 2.       Network Module Numbers and Descriptions
Product Number
Product Description
WS-C3850-24XU
WS-C3850-12X48U
WS-C3850-12XS
WS-C3850-24XS
C3850-NM-4-1G
4 x Gigabit Ethernet network modules
Supported
Not supported
C3850-NM-2-10G
4 x Gigabit Ethernet/2 x 10 Gigabit Ethernet network modules
Supported
Not supported
C3850-NM-4-10G
4 x Gigabit Ethernet/4 x 10 Gigabit Ethernet network modules
Supported
Supported
C3850-NM-8-10G
8 x Gigabit Ethernet/8 x 10 Gigabit Ethernet network modules
Supported
See note
C3850-NM-2-40G
2 x 40 Gigabit Ethernet network modules
Supported
See note
Table 3.       Network Module Compatibility Matrix
Models
Network Modules
WS-C3850-24T
C3850-NM-4-1G, C3850-NM-2-10G
WS-C3850-48T
C3850-NM-4-1G, C3850-NM-2-10G, C3850-NM-4-10G
WS-C3850-24P
WS-C3850-48P
WS-C3850-48F
WS-C3850-24U
WS-C3850-48U
WS-C3850-24XU
C3850-NM-4-1G, C3850-NM-2-10G, C3850-NM-4-10G, C3850-NM-8-10G, C3850-NM-2-40G
WS-C3850-12X48U
WS-C3850-12S
WS-C3850-24S
WS-C3850-12XS
C3850-NM-4-10G
WS-C3850-24XS
WS-C3850-48XS
None
Reference: http://www.cisco.com/c/en/us/products/collateral/switches/catalyst-3850-series-switches/data_sheet_c78-720918.html
Please rate the comment if it is useful
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
It is compatible..
Turns out I had to set 'speed nonegotiate' on the interface  .. The device the fiber is connected to on the other end I do not have access to, so I am not sure why speed nonegotiate on the interface is required, but it worked.
Good to know Robert, thanks.
