C3850 -- Power Stack only Connecting on One Side
rsmith2720
I am working with a C3850 2-stack, where the power stack cables are showing that they're only connected on one side. I have tried reseating and swapping the cables out for brand new ones, but switch 1 is continuing to show "not connected" while switch 2 shows "connected" and has the S-PWR light lit up green on the switch.
Power stack name: Powerstack-1
Stack mode: Power sharing
Stack topology: Standalone
Switch 1:
Power budget: 715
Power allocated: 551
Low port priority value: 22
High port priority value: 13
Switch priority value: 4
Port 1 status: Not connected
Port 2 status: Not connected
Neighbor on port 1: 0000.0000.0000
Neighbor on port 2: 0000.0000.0000
Switch 2:
Power budget: 569
Power allocated: 264
Port 1 status: Connected
Port 2 status: Connected
Neighbor on port 1: Switch 1 - 00e1.6d21.ca00
Neighbor on port 2: Switch 1 - 00e1.6d21.ca00
Enes Simnica
Level 5
Level 5
@rsmith2720 I can tell 100% that the issue is with switch 1's power stack ports. Cause since switch 2 sees the connections but Switch 1 reports both ports as “not connected.” That usually points to a hardware problem on Switch 1 (bad power stack module or backplane), not the cables. In these kind of situations i usually check the logs with show loggings, for any stack power errors. After that verify the switch is running a supported IOS XE version, and of course If ports still don’t come up, it’s likely an RMA case for Switch 1’s power stack ports.....
check this: Catalyst 3850 Switch Hardware Installation Guide - Switch Installation [Cisco Catalyst 3850 Series Switches] - Cisco
-Enes
CCNP x2 Enterprise
Your Friendly Networking Ninja
more Cisco?!
more Gym?!
If this post solved your problem, kindly mark it as Accepted Solution. Much appreciated!
Jens Albrecht
Hello @rsmith2720,
there are a few things you can try on switch 1:
  • Disable and then re-enable the power-stack ports. This can be done with the commands:
    ! Disable power stack ports:
    stack-power switch 1 port 1 disable
    stack-power switch 1 port 2 disable
    ! Re-enable power stack ports:
    stack-power switch 1 port 1 enable
    stack-power switch 1 port 2 enable​
  • Do a local loop test on switch 1 by connecting ports 1 and 2 with a know working cable
  • Cold reboot of switch 1 (power down, pull all cables, wait a minute, recable and start) and retest
If none of these steps help, then it is probably time to RMA the switch as the power stack ports cannot be replaced.
HTH!
Show version <<- check if both SW run same Ver. Or not
MHM
