01-19-2014 12:00 PM - edited 03-07-2019 05:39 PM
Hi, i have an issue with a c3kx sm 10 module on a 3750x. I have upgraded the switch and the module to ios universal 152-1e1. When i issue the command sh switch service-module, i get h/w status:ok , cpu link: notconnected, cpu version: n/a. The upgrade was performed in a stack configuration of 2 3750x switches.
Can you please advice?
01-19-2014 01:51 PM
If this is for the Netflow module, you need an additional software to get it working.
Here is a link with instruction on how to upgrade:
01-20-2014 05:44 AM
The module c3kx-sm10g, int the show switch service module shows: h/w ok but cpu link not connected.
I am trying to upgrade it in the version c3kx-sm10g-tar.152-1.e1.tar the switch ios image is now c3750e-universalk9-mz.152-1.e1.bin.
I use the command archieve downlad-sw /overwrite
archieve downlad-sw /allow-feature-upgrade
but i get the message: error: the image in the archieve which would be used to upgrade system number 1 does not support that system type.
how shall i proceed.
01-30-2014 08:08 AM
It seems that the module was defected, hence i proceeded to an rma. The new module is working perfectly!!
Thank you all for your help!
