C4510RE terminated abnormally
jacobxu80
Hi I am unboxing 2x cartons of C4510RE chassis and find this booting up fault consistently appearing in both chassis.
Has anyone encountered this before ?
Please find attached logs. Thank you and Good Day!
Leo Laohoo
Try to boot a lower version, like 3.6.X or 3.7.X. If the line card boots up properly, post the complete output to the command "sh version".
I want to see what version is the ROMmon, For 3.8.X, the supervisor card must be running 15.1(1r)SG5 (or later).
jacobxu80
Thanks it’s working fine now after replacing faulty line card with working 1.
Cisco IOS Software, IOS-XE Software, Catalyst 4500 L3 Switch Software (cat4500es8-UNIVERSALK9-M), Version 03.08.04.E RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2017 by Cisco Systems, Inc.
Compiled Thu 06-Apr-17 08:19 by prod_rel_team
Cisco IOS-XE software, Copyright (c) 2005-2015 by cisco Systems, Inc.
All rights reserved. Certain components of Cisco IOS-XE software are
licensed under the GNU General Public License ("GPL") Version 2.0. The
software code licensed under GPL Version 2.0 is free software that comes
with ABSOLUTELY NO WARRANTY. You can redistribute and/or modify such
GPL code under the terms of GPL Version 2.0.
(http://www.gnu.org/licenses/gpl-2.0.html) For more details, see the
documentation or "License Notice" file accompanying the IOS-XE software,
or the applicable URL provided on the flyer accompanying the IOS-XE
software.
ROM: 15.1(1r)SG8
MB-L1S1-4510RE-ES01 uptime is 46 minutes
Uptime for this control processor is 41 minutes
System returned to ROM by SSO Switchover
System image file is "bootflash:/cat4500es8-universalk9.SPA.03.08.04.E.152-4.E4.bin"
Jawa Revision 3, RadTrooper Revision 0x0.0x41, Conan Revision 0x1B9E
Last reload reason: power-on
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
License Information for 'WS-X45-SUP8-E'
License Level: ipbase Type: Permanent
Next reboot license Level: ipbase
cisco WS-C4510R+E (P5040) processor (revision 2) with 4194304K bytes of physical memory.
Processor board ID JAD2118046D
P5040 CPU at 2.2GHz, Supervisor 8-E
Last reset from PowerUp
2 Virtual Ethernet interfaces
216 Gigabit Ethernet interfaces
88 Ten Gigabit Ethernet interfaces
511K bytes of non-volatile configuration memory.
