04-15-2009 08:34 PM - edited 03-06-2019 05:12 AM
Hi NetPro,
i got this major problem. anyone can help ?
Apr 16 03:49:39.621: %C4K_PKTPROCESSING-4-UNKNOWNBRIDGEORROUTE: (Suppressed 2 times)Unable to determine whether to route or bridge replicated softwar
e-processed packet with source address 00:16:E6:0E:D7:C2 and destination address 00:00:0C:07:AC:64
.Apr 16 04:17:39.994: %C4K_PKTPROCESSING-4-UNKNOWNBRIDGEORROUTE: Unable to determine whether to route or bridge replicated software-processed packet w
ith source address 00:1A:4D:DF:7C:EB and destination address 00:00:0C:07:AC:64
.Apr 16 05:53:05.692: %C4K_PKTPROCESSING-4-UNKNOWNBRIDGEORROUTE: (Suppressed 5 times)Unable to determine whether to route or bridge replicated softwar
.Apr 16 06:08:11.778: %C4K_PKTPROCESSING-4-UNKNOWNBRIDGEORROUTE: (Suppressed 2 times)Unable to determine whether to route or bridge replicated softwar
e-processed packet with source address 00:15:58:E6:23:F3 and destination address 00:00:0C:07:AC:64
.Apr 16 10:32:45.192: %C4K_PKTPROCESSING-4-UNKNOWNBRIDGEORROUTE: (Suppressed 1 times)Unable to determine whether to route or bridge replicated softwar
e-processed packet with source address 00:1A:4D:DF:7D:7D and destination address 00:00:0C:07:AC:64
.Apr 16 11:21:56.283: %C4K_PKTPROCESSING-4-UNKNOWNBRIDGEORROUTE: (Suppressed 2 times)Unable to determine whether to route or bridge replicated softwar
.Apr 16 11:33:41.296: %C4K_PKTPROCESSING-4-UNKNOWNBRIDGEORROUTE: (Suppressed 8 times)Unable to determine whether to route or bridge replicated softwar
.Apr 16 11:49:29.607: %C4K_PKTPROCESSING-4-UNKNOWNBRIDGEORROUTE: (Suppressed 14 times)Unable to determine whether to route or bridge replicated softwa
re-processed packet with source address 00:1A:4D:DF:79:A8 and destination address 00:00:0C:07:AC:64
.Apr 16 12:00:55.324: %C4K_PKTPROCESSING-4-UNKNOWNBRIDGEORROUTE: (Suppressed 4 times)Unable to determine whether to route or bridge replicated softwar
.Apr 16 12:11:52.200: %C4K_PKTPROCESSING-4-UNKNOWNBRIDGEORROUTE: (Suppressed 8 times)Unable to determine whether to route or bridge replicated softwar
e-processed packet with source address 00:15:58:E0:B3:66 and destination address 00:00:0C:07:AC:64
thanks.
04-15-2009 09:04 PM
From: http://www.cisco.com/en/US/docs/switches/lan/catalyst4500/12.2/50sg/system/messages/emsg.html
When a replicated packet is sent to the software by an output ACL, the hardware does not indicate whether the packet needs to be bridged or routed.
When resources are exhausted or when the ACLs programmed in the hardware cannot handle processing directly (such as ACLs matching TCP flags), the Supervisor Engine III sends the packets to software for processing. If the software cannot determine whether to bridge or route, the packet might be dropped. This drop indicates that the packet was directed to a Hot Standby Routing Protocol (HSRP) router group MAC address.
This is an informational message only. No action is required.
04-16-2009 12:41 AM
Hi Leolaohoo.
thanks for your information, basically i got that info from cisco msg decoder as well. but i was just thinking if the sup engine is busying for these msg it will use a lots of the cpu proc , then it will hit to the high cpu utilization soon... isn't it ?
your reply will be highly appreciated.
thanks.
04-16-2009 04:04 AM
That depends on your IOS, configuration and your network. Try doing "sh processor cpu history" just to make sure.
09-29-2009 07:45 AM
Hi All,
I'm having the same problem here. From what I've seen, this is an informational message but, does anyone know if it's possible not to have this message logged on the syslog server ?
Mary
09-29-2009 09:08 AM
Mary you can log any console message to syslog server.
Issue: logging console.
Here is the documentation, with the commands needed:
09-29-2009 09:09 AM
Check if you also see messages such:
C4K_L3HWFORWARDING-3-FWDCAMCONSISTENCYCHECKFAILED
If those appear quite often, you may have a hardware failure.
