c6506 (Sup2/msfc2/pfc2) MLS issue / not mls handled traffic
ronnyboesger
Hi folks,
i have the following issue with a c6506 with sup2,msfc2 and a pfc2:
The most traffic is NOT process with MLS, it seems it is processed through the msfc.
Most of the inbound traffic (90%) seems to be not mls switched, this shows me the msfc show intxx command.
If you need more info, please let me know.
6 Replies 6
Giuseppe Larosa
Hello Ronny,
post the output of sh mls on the L2 supervisor to see if it has detected and would use the MSFC as MLS RP.
Hope to help
Giuseppe
Hi Giuseppe,
thank your for help, following the output:
> sh mls
Total packets switched = 1006234374864
Total bytes switched = 451868540482264
Total routes = 261525
Total number of Netflow entries = 76489
Long-duration flows aging time = 320 seconds
IP statistics flows aging time = 16 seconds
IP statistics flows fast aging time = 0 seconds, packet threshold = 0
IP Current flow mask is Full flow
Netflow Data Export version: 5
Netflow Data Export enabled
Netflow Data Export configured for port xxxx on host xxx.xxx.xxx.xxx
Secondary Data Export configured for port xxxx on host xxx.xxx.xxx.xxx
Total packets exported = 28283078
Total Secondary packets exported = 28283078
Total NDE collectors configured = 2
Destination Ifindex export is enabled
Source Ifindex export is enabled
Bridged flow statistics is enabled on vlan(s) 1,20,887,888.
Bridged flow statistics is disabled on vlan(s) 10-11,1006-1011,1016.
Cannot get bridged flow statistics information of vlan(s) 1002-1005.
IPX statistics flows aging time = 16 seconds
IPX flow mask is Destination flow
IPX max hop is 255
Module 15: Physical MAC-Address 00-0f-35-xx-xx-xx
Module 15 is the designated MSFC for installing CEF entries
Packets are rate limited to router at the rate of 20000 pps
Load balancing hash is based on source and destination IP addresses
Per-prefix Stats for ALL FIB entries is Enabled
kind regards,
ronny
Hello Ronny,
everything looks fine but I see that you are receveing a BGP full table:
msfc# sh cef drop
CEF Drop Statistics
Slot Encap_fail Unresolved Unsupported No_route No_adj ChkSum_Err
RP 382089049 102396 0 6081869 0 0
msfc# sh cef not-cef-switched
CEF Packets passed on to next switching layer
Slot No_adj No_encap Unsupp'ted Redirect Receive Options Access Frag
RP 241681182 0 0 0 81491042 0 0 0
Verify if CEF MLS is not short of memory in that case ip packets with destinations not present in CEF tables are process switched = sent to MSFC
Hope to help
Giuseppe
Hello Giuseppe,
the msfc says:
#show mem sum
Head Total(b) Used(b) Free(b) Lowest(b) Largest(b)
Processor 41D122E0 439278880 231796660 207482220 177103952 134536428
I/O 8000000 67108864 5488784 61620080 53247648 57810972
and the CatOs says:
Memory Used: 67060512
Free: 75777856
Total: 142838368
so there should be enough free mem.
I have read all cisco troubleshouting and info docs. Vor 2 weeks everything was fine, nothing was changed in this time.
Are there any further hints on this ?
thanks ronny
Hello Ronny,
two possible actions:
a) IP Current flow mask is Full flow move to destination flow mask in the hope to change
b) schedule a catalyst reload and see if in the first days MLS is working (last resort)
Having free memory on MSFC and supervisor is necessary but could be not enough. It depends on the type of linecards you have on the chassis if they have DFC submodules they will try to store the CEF tables on them.
You can verify with show module on the supervisor if there are DFCs in the linecards.
Hope to help
Giuseppe
Hello Giuseppe,
This action was already checked. No success on this.
No, we don`t have any dCEF Modules in that Cisco, there are:
a 1000BaseX Ethernet WS-X6408-GBIC
a 10/100/1000BaseT Ethernet WS-X6148-GE-TX
i will schedule a reload of this router, i think this would solve this issue for a while,perhaps we need a ios /catos update.
best regards,
ronny
And once again, thank you for your time to help on this issue :)
