C6506-SUP2-NVRAM_Battery Problem
ctjloveinnet
Hi there:
I found the following event log in C6506
Jul 17 07:45:18.186: %SYS-5-CONFIG_I: Configured from console by otnadmin on vty0 (XXX.XXX.XXX.XX)
Jul 23 15:41:37.551: %HA_EM-6-LOG: Mandatory.go_nvrambatterymon.tcl: GOLD EEM TCL policy for TestNVRAMBatteryMonitor
Jul 23 15:41:37.787: %CONST_DIAG-2-LOW_NVRAM_BATTERY_FOR_THREE_DAYS: Low NVRAM battery power detected for 3 consecutive days on module 5.
and this problem may be corrected by removing the SUP and then pressing the NVRAM_Battery
If I fail the task that press battery,
Is there any disadvantage about RMA?!
Reza Sharifi
This bug is only for Sup-2T.  Do you have Sup-2 or 2T?  If it is 2T and the bug solution provided does not fix the issue, open a ticket with TAC and RMA It.
Reza Sharifi
