C6509, FWSM Failover, C3560G, Vlans
ioan_ploscariu
I have the folowing network scenario:
In the central node:
   1 Catalyst 6509
   2 FWSM (failover and routed mode configured)
In the remote locations:
    1 Catalyst 3560G
I want to have more than one vlans behind catalyst 3560G switches.
How i configure the firewall and the routing between FWSM and C3560G?
Scenario is presented in the attached draft (tested for one vlan).
Thank you.
Jon Marshall
   1 Catalyst 6509
    1 Catalyst 3560G
Thank you.
Not sure what your query is ?
Is the 3560G routing the vlans or are they meant to be routed on the FWSM ?
Jon
I want the FWSM to make NAT for vlans even if one firewall module failed and the PC behind switches  to have internet access through firewall module.
How i configure the firewalls and the switches to make this happen?
Thank you.
Thank you.
Hi ,
For above requirement create a trunk configuration between 3560G and 6509 switch and push those vlans into FWSM,Drop the gateways of the pc to FWSM vlan interface and drop a reverse route for vlan subnet towards the switch side.
For failover configuration on FWSM Active/passive check out the below link
http://www.cisco.com/en/US/docs/security/fwsm/fwsm32/asdm52f/user/guide/switch.pdf
For natting configuration in FWSM check out the below link
http://www.cisco.com/en/US/docs/security/fwsm/fwsm22/configuration/guide/quick.html
Hope to help !!
Ganesh.H
Remember to rate the helpful post
