C6513 intermitten every 30 second
edgar_pascal
my C6513 intermittent every 30 second.
reply for 30 second and timeout 6 times and reply again continuosly.
Attached the sample.
Please help?
Lian
8 Replies 8
pstebner10
Lian-
Are you running CEF? If not, the 6500s use a redirect mechanism to move packets that leave the sup module. This causes high CPU, so there is a built-in throttle mechanism to prevent DoS type attacks. So, the sup module can drop your pings because they come in at a high rate. Try enabling CEF and see if your issue goes away.
HTH,
Paul
Paul,
Yes, my C6500'S was'nt run CEF, it is neccessary to config CEF in my all C6500's, can you show me to config CEF.
Attached 2 of C6500's config.
Lian
Paul,
Lian
Lian-
For IOS all you need to enter is:
ip cef
You may also want to take alook at this: http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/catos/8.x/configuration/guide/cef.html
HTH,
Paul
Paul,
one more question what is benefit and risk if i implement of ip cef command?
Lian
Lian-
I'm not really aware of any risk. Benefits are listed here: http://www.cisco.com/en/US/docs/ios/12_1/switch/configuration/guide/xcdcef.html
HTH,
Paul
Hi Paul,
Thanks very much about CEF your very helpful.
Paul,
anoter question
How to find high broadcast or multicast traffic on C6500 source and destination address on switch or per interface?
Lian
Hi Paul,
thanks for you help i just reload my c6500
and now back to normal.
Lian
