12-02-2015 03:10 AM - edited 03-08-2019 02:55 AM
C6800-32P10G line card is combatible with 6509-E chassis with VS-S2T-10G-XL ?
12-02-2015 03:15 AM
looks to be compatibile with 2Ts
Product Details
C6800 Family 32-Port 10-Gigabit Ethernet Fiber Module
The C6800 Family 32-port 10-Gigabit Ethernet Fiber Module is suitable for deployment in all campus aggregation and core networks.
● Two models: C6800-32P10G, a 32-port 10-Gigabit Ethernet Fiber Module with DFC4 (see Figure 1), and C6800-32P10G-XL, a 32-port 10-Gigabit Ethernet Fiber Module with DFC4XL
● Backplane connection: 160-Gbps backplane bandwidth in 6807XL; 80 Gbps backplane bandwidth in 6500-E chassis
● Chassis/slot support: Can occupy slots 1-2 and 5-7 in a Cisco Catalyst 6807-XL. Can occupy any slot in Cisco Catalyst 6503E, 6504E, 6506E, 6509E, and 6509-V-E. Can occupy slots 1-6 and 9-13 in a Cisco Catalyst 6513-E
● Supervisor engine: Compatible with Supervisor Engine 2T and Supervisor Engine 2TXL
● Distributed forwarding and performance: Comes equipped with factory-installed dual (2) DFC4-E or DFC4-EXL daughter cards
The C6800 Family 32-port 10-Gigabit Ethernet Fiber module provides up to 160 10-Gigabit Ethernet fiber ports in a single Cisco Catalyst 6807-XL Switch chassis or up to 320 10-Gigabit Ethernet fiber ports in a Cisco Catalyst 6807-XL Virtual Switching System (VSS) 2T. It also provides up to 352 10-Gigabit Ethernet fiber ports in a single Cisco Catalyst 6513-E Switch chassis, or up to 704 10-Gigabit Ethernet fiber ports in a Cisco Catalyst 6500 VSS 2T.
12-02-2015 06:11 AM
Hello ,
As per below link on C6800-32P10G line card datasheet, it seems to be compitabile.
Have a look for your reference.
C6800-32P10G Line card support
Hope it Helps..
-GI
