C6800IA
sdominko
Does anyone know how to configure C6800IA renumbering when C6800IA switches in stack?
I would like to change (see printout below) mod 1 into 2 and vice versa. In case we have Cisco Catalyst 3650 switch stack it can be done easy with changing switch stack number priority and reload.
Regards,  Stefan D.
6880_DC1#show module fex
 Switch Number:   101   Role:                     FEX
Mod Ports Card Type                              Model              Serial No.
  1   48  C6800IA 48GE POE                       C6800IA-48FPDR     FDO1842I03F
  2   48  C6800IA 48GE POE                       C6800IA-48FPDR     FDO1842I03C
Mod MAC addresses                       Hw    Fw           Sw           Status
  1  0cf5.a439.8680 to 0cf5.a439.86b3   0.0   Unknown      15.0(2)EX7   Ok
  2  0cf5.a439.8800 to 0cf5.a439.8833   0.0   Unknown      15.0(2)EX7   Ok
Mod  Online Diag Status
  1  Pass
  2  Pass
sdominko
I found out it can be done, but only trough console access not parent switch.
1.Power ON the 6800IA, without connecting any Stack cables or the uplink connections.
2.Once the IA has booted up, connect the console cable to the IA and renumber the IA switch number to the old IA which has gone using the below steps.
    FEX-0#conf t
    FEX-0(config)#switch 1 renumber 2
