C6807 slowness
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
06-04-2022 11:09 PM
I have 2 C6807XL switches works as a VSS , recently i installed 10G-32Port module on both switches , but i noticed the switch become slow ( when i telnet it take few seconds to accept command) .
i tried to find out if there is any error on 10G interfaces but i found nothing ..
i am not sure if the problem from the new 10G module or the switch is overloaded because i am running DMVPN, OSPF, and EIGRP , and the uplinks to the ISPs is 1G , and the downlinks to DC FWs is 4x10G ( from new module , 2 Portchannels )
any help will be appreciated
- Labels:
Catalyst 6000
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
06-04-2022 11:32 PM
No, I don't think the switch is overloaded with that many connections. You may have hit a bug by inserting 10G-32Port module into the chassis that is causing high CPU. Take a look at the processes by using the command "sh process cpu sort | exe 0.00" and see what object is taking up too much processor.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
06-05-2022 12:03 AM
Thank you for your replay,
look like processor utilization is normal 53% - 60%
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
06-05-2022 02:42 AM
Why OIR process utilize your SW? Do you use it recently?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
06-05-2022 03:28 AM
NO i didn't use , i am not sure if it is running by default
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
06-05-2022 03:50 AM
Check doc. I attach below
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
06-05-2022 02:45 AM
No, it is not. Look at the output again. The highest process using the CPU is <5% but the aggregate value 57%? No, that is wrong in so many levels.
What is the uptime?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
06-05-2022 03:30 AM
i restart the switches 2 days before ..
is that high CPU utilization related to the installation of the new modules ?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
06-05-2022 05:36 PM
Not sure. I suspect that it is a CPU hog/memory leak. If the pair have been rebooted recently, I am going to recommend upgrading the firmware to, say, 15.2(1)SY8.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
06-04-2022 11:32 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
06-05-2022 03:05 AM
Check this doc.
If There is issue with OIR
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
06-05-2022 09:14 AM
do this
diagnostic bootup level complete
show diagnostic mode all
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
06-05-2022 10:08 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
06-05-2022 04:44 AM
Did you notice any complain from network users or did you notice any slowness on the network that depends on this VSS?
ping, traceroute, file transder,etc?
Slow response on commands can be a TACACS problem, if you are using it. Not necessarilly you have a problem on the switch itself.
Aside, mamangement traffic like telnet ssh is not treated in the same way as data traffic.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
06-05-2022 05:21 AM
yes , if i ping any ip on C6800 it is very bad , 5~10 1ms replies then timed out ..
but if i ping any other destination ( Traffic pass through core switch) it is ok.
also, if i ping any destination connected on VLAN1020 ( i am using this VLAN as a source for DMVPN tunnel ) while other tunnels on the other VLANs working fine ..
