C6880-X Module in PwrDown
swedwards
Our Site had a cooler system failure this morning and 1 of our modules when down and the status shows it in PwrDown, its in module #1 and the model part is a C6880-X-16P10G, is there a command to get it back online with out rebooting the whole switch? We have 2 C6880-X VSS together... I tried a command I used in the pass on my 6500 switch with no luck. The command was hw-module switch 2 module 1 reset...
Mark Malone
Hi ...... power enable switch x module x
that should do it for VSS in conft
Mark Malone
Thanks fpor your reply... module back online...
