WS-X45-SUP8-E Booting to ROMMON After Power Outage
jvasilko
I have multiple 4510 switches with dual SUP8 modules running at a new campus site.  The site has frequent power outages and every time this happens, one of the switches boots to ROMMON and needs to be manually booted back into service.  All of the other switches come back without issue.  I don't see anything obvious with the config to understand why this is happening.  Anyone have any experience with this and have any suggestions for resolution?  Thanks in advance.
Reza Sharifi
Can you post the output of "sh redundancy" from that switch.
Redundant System Information :
       Available system uptime = 5 weeks, 8 hours, 19 minutes
Switchovers system experienced = 0
              Standby failures = 0
        Last switchover reason = none
                 Hardware Mode = Duplex
    Configured Redundancy Mode = Stateful Switchover
     Operating Redundancy Mode = Stateful Switchover
              Maintenance Mode = Disabled
                Communications = Up
Current Processor Information :
               Active Location = slot 5
        Current Software state = ACTIVE
       Uptime in current state = 5 weeks, 8 hours, 17 minutes
                 Image Version = Cisco IOS Software, IOS-XE Software, Catalyst 4500 L3 Switch  Software (cat4500es8-UNIVERSAL-M), Version 03.07.01.E RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2015 by Cisco Systems, Inc.
Compiled Tue 28-Apr-15 10:05 by prod
               BOOT = bootflash:packages.conf,1;slavebootflash:packages.conf,1;
        Configuration register = 0x102
Peer Processor Information :
              Standby Location = slot 6
        Current Software state = STANDBY HOT
       Uptime in current state = 5 weeks, 8 hours, 11 minutes
Can you change the configuration resister to 0x2102 and reload?
Everything else looks good. If this does not resolve it, you may want to open a ticket with TAC.
Reza.....I think this is going to be the solution.  As soon as I looked at that compared to the others, it was obvious.  I will let you know if it works, I can't reload the switch right now as it is in production.
