C6K - randomly high CPU usage
Radim Jurica
Level 2
Level 2
Hi all,
we have two c6509 budled in VSS. I have noticed randomly high usage of CPU, sometimes up to 99% in peaks. I have found that it can be generated by SNMP engine. So I unconfigure all SNMP things. But situation is the same.
I would like to know if this state is OK or not. Any help with this?
CPU shows are enclosed in file.
Thank you very much for explanation/comments!
Radim
dominic.caron
Level 11
Level 11
Random peak are no problem. Your average cpu is stable at around 20% and you are doing IP SLA and netflow export. The router might only be doing some low priority task with the cpu.
