Hi I want to prepare
to convert a pair of C6K5 to VSS. fortunately I have two spare-chassis and two spare SUPs. I plan to just replace the SUP with the right config on it.
Unfortunately I do not have the same Line-cards as Spare which I have in production.
So during converting to VSS there the provisioning section appears in the config
module provision switch 1
slot 1 slot-type 227 port-type 60 number 8 virtual-slot 17
slot 5 slot-type 254 port-type 31 number 2 port-type 61 number 1 port-type 60 number 2 virtual-slot 21
slot 8 slot-type 147 port-type 61 number 48 virtual-slot 24
slot 9 slot-type 147 port-type 61 number 48 virtual-slot 25
module provision switch 2
slot 1 slot-type 227 port-type 60 number 8 virtual-slot 33
slot 2 slot-type 148 port-type 60 number 4 virtual-slot 34
slot 5 slot-type 254 port-type 31 number 2 port-type 61 number 1 port-type 60 number 2 virtual-slot 37
slot 8 slot-type 147 port-type 61 number 48 virtual-slot 40
slot 9 slot-type 147 port-type 61 number 48 virtual-slot 41
I also found out which physical slot is mapped to which virtual slot, but I could never find a list with
slot-types for the differnt possible Line-cards as well as the port-type.
Having this List it would be possible to Preprovioning all Module we have in production environment in our Lab-VSS-Bundle, put the correct config on it, and then in a maintanance-window just replace both production-boxes with the preconfigured Sups.
Any idea where to get this list of slot-types and port-types.
Thx
Hubert
