C819G-4G-GA-K9
lowhongni
Hi everyone,
May i know C819 can support 2 sim card slot? by default, the router is come with 1 slot for sim card only.
However,is it need to update IOS to latest version to support 2 sim card?
Name
Description
Smartnet Duration
Qty
C819G-4G-GA-K9
C819 M2M 4G LTE for Global, 800/900/1800/2100/2600 MHz,HSPA+
CON-SNT-C819LTE
SNTC-8X5XNBD C819 M2M 4G LTE for Global, 800/900/1800
36 month(s)
CAB-ETH-S-RJ45
Yellow Cable for Ethernet, Straight-through, RJ-45, 6 feet
 Notes : The above router model is inclusive of the following items.
S84GUK9-15503M
Cisco 8004G UNIVERSAL
MC7304-4G-LTE-GA
Sierra MC7304 Global LTE, Band 1, 3, 7, 8, 20
4G-AE010-R
Single Unit antenna Extension Base (10 foot cable included)
CAB-ETH-S-RJ45
FL-C810-WAASX
810 Series WAAS Express
SL-810-AIS
810 Series Advance IP Services License
ISR-CCP-EXP
Cisco Config Pro Express on Router Flash
SL-810-ADVSEC
810 Series Advance Security Software License
PWR2-20W-AC
C819 20W AC power supply with WiFi
4G-LTE-ANTM-D
4G LTE articulating dipole antenna 700MHz-2600MHz bands
FW-MC7304-LTE-GB
FW Switching Load for MC7304 Global
CAB-AC2UK
AC Power cord UK
Mark Malone
see doc FAQ
https://www.cisco.com/c/en/us/products/collateral/routers/800-series-routers/qa_c67-678460.html
Q. How many SIM slots are supported on the Cisco 819 ISRs?
A. Two SIM card sockets are located under the back of the HSPA+/HSPA/UMTS/EDGE/GPRS based routers, with a cover for protection. Dual SIM card slots allow customers to subscribe cellular services from two different carriers, and they use one cellular link to back up the other one for mission-critical applications. When the cover is open, the router stays functional and powered up, except that the 3G modem needs to be powered off.
