C887VA-W-E-K9 AP 802 AUTONOMOUS HOSTNAME DNS RESOLVE ISSUE
Sebastian Sajak
Hello:). Please help me because I was stuck on the configuration of the AP.
Clients connected wired can connect to the host (Matrix_Storage) via the IP address and hostname but clients connected wirelessly can connect to a host (Matrix_Storage) only by entering its IP address.
What is wrong? Where did I make a mistake?
In the attached configurations of the AP and the Router.
Regards, Seba.
5 Replies 5
I am interested to know how the clients get their IP addresses, as in your DHCP config, all addresses are excluded on the 192.168.1.0/28 network except 192.168.1.10 which gets assigned to the router. or is the IP addressing of clients done via theradius server.
regards
Richard.
I fixed configuration but still no change :(
johnd2310
Level 8
Level 8
What device is using 192.168.1.1  and what is your internal dns/wins server?
John
**Please rate posts you find helpful**
192.168.1.1 - it's address of router C887VA-W-E-K9
my internal server address - 192.168.1.1
Set up your internal server to do dns and set wired and wireless clients to use it as dns server.
Configure required resources on the dns server
John
