02-10-2018 12:00 PM - edited 03-08-2019 01:47 PM
Dear all,
I have a Cisco C897VAW-E-K9, with this IOS C800-UNIVERSALK9-M, Version 15.7(3)M1, with the power supply LITEON 341-0502-01.
The PoE LED is orange and the PoE doesn't work, I tried several IOS but it doesn't change anything.
Also the cli "show power inline " isn't recognize.
any idea ?
thank's in advance
Julien
Solved! Go to Solution.
02-10-2018 01:12 PM
how old is the router ? The internal PoE card might be damaged or malfunctioning. If possible, open the chassis and reseat the card (see attached document for instructions):
02-10-2018 01:12 PM
02-10-2018 01:55 PM
Post the complete output to the command "sh inventory raw". I want to see if the PoE daughter card (800-IL-PM-4) is present and if the 125w PSU is used.
02-10-2018 04:52 PM
To make PoE work you have to have a PoE daughter card installed (not their by default) and a larger 125W power supply. Have you got both of these?
