C9000 Series switch - RFID tags
kapslock
Hello, is it possible to return a serial number or hostname via the RFID tag, on the new 9200L and 9300L series switch?
I have not touched RFID before, and any help is appreciated, including configuration examples :)
Best regards
/K.
Mark Elsen
 - According to the document below it has support for retrieving the serial number through RFID
 https://www.cisco.com/c/dam/en/us/products/collateral/switches/catalyst-9300-series-switches/white-paper-c11-739703.pdf
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
Mark Malone
havent done this but looks like its possible , have you got a reader yes
How end users access tag dataTag contents are accessed by using EPC Global Class 1, Generation 2, ISO 18000-6C-compliant fixed or mobile readers. Any RFID system that supports EPC Generation 2 is able to access data from Cisco Catalyst 9000 family RFID-enabled products for asset tracking and asset management.End users are also able to access a tag’s data by using Telnet, a web browser, serial communications to the reader, and third-party middleware applications
I dont see a 9k config guide but its ios-xe like 3850 so these commands may work
Configuring RFID Tag Tracking
https://www.cisco.com/en/US/docs/switches/lan/catalyst3850/software/release/3se/consolidated_guide/b_consolidated_3850_3se_cg_chapter_01111001.html
Leo Laohoo
I do believe this feature is not yet enabled.
Faffe
I think the
location rfid status
 command refers to tracking rfid tags throughout your network, and is not in any way related to the rfid tags present on your device.
