C9200-24P-E
abtt-39
Level 3
Level 3
I would like information on the C9200-24P-E range of switches.
I would like to order some. With the essentials license, can these switches do default routing? "ip routing" for inter-vlan routing? Can I create svi? How many? Can I add static routes?
Reading the data sheets, I think yes, the 9200s are switches with L2/L3 features, but I was just to be sure
What service does the C9200-DNA-E-48-5Y option cover? If I want to open a TAC, for example, is this the option I need to subscribe to?
acampbell
I would advise you to read the C9200 data sheet.
https://www.cisco.com/c/en/us/products/collateral/switches/catalyst-9200-series-switches/nb-06-cat9200-ser-data-sheet-cte-en.html
You will find the info you are looking for in there.
Regards, Alex. Please rate useful posts.
