05-19-2025 02:23 AM
Hello everyone ,
Please can someone help me with my issue acI'm experiencing a recurring issue with my C9200CX-12T-2X2G switch. Every 2–3 days, the switch unexpectedly reboots and enters ROMMON mode. When I try to access the flash from ROMMON, I receive the following errors:
switch: flash_init Error: command 'flash_init' not found. switch: dir flash: Unable to read ExtX super block Error[1]: Failed to list directory! switch: dir sdflash: Error[22]: Failed to open directory!
Additionally, running the ?
command in ROMMON shows that flash_init
isn't even listed as a valid command.
After manually rebooting the switch, it boots normally and operates without issue — until the problem recurs after a few days.
I’m currently running IOS XE 17.12.1r, and the switch uses the primary ROMMON image. I’ve checked the boot variables and configuration, and everything seems correct.
Has anyone else experienced this issue? Could this be related to flash corruption or a software bug in the current version? Any suggestions on how to further diagnose or resolve this would be appreciated.Thanks in advance!
05-19-2025 02:28 AM
- It looks like you have file system corruption in the flash (names may vary) ; checkout
https://www.cisco.com/c/en/us/support/docs/ip/syslog/221138-troubleshoot-disk-errors.html#toc-hId--608350784
M.
05-19-2025 02:42 AM - edited 05-19-2025 02:52 AM
hi thanks for your reply i'll check the link
05-19-2025 02:33 AM
Thanks for sharing this. Just curious — have you tried upgrading or downgrading from 17.12.1r to see if the behavior changes? There were some known ROMMON and file system bugs in earlier versions of IOS XE, so it might help to test with a stable long-term release like 17.9.x.
05-19-2025 02:41 AM
Thanks for your reply
The switch was initially running cat9k_lite_iosxe.17.12.05.SPA.bin, and I upgraded it to the recommended version 17.12.1r, but unfortunately, I’m still encountering the same issue. I’ll try downgrading to the 17.9.x to see if that makes a difference.
Also, I have another question:
Is there a way to simulate traffic on the switch for testing purposes without actually connecting it to the production network? I'd like to validate the behavior under traffic conditions while keeping it isolated.
Appreciate your help!
05-19-2025 03:05 AM
If the switch is still in ROMMON, post the complete output to the command "set".
05-19-2025 03:12 AM
Unfortunately, no I rebooted the switch to downgrade the firmware, and it's no longer in ROMMON mode. I’ll try to capture the information if the switch enters ROMMON mode again
05-19-2025 06:10 AM - edited 05-19-2025 06:12 AM
the switch rebooted and entered ROMMON mode again here's the output :
Switch#
Initializing Hardware...
System Bootstrap, Version 17.12.1r [FC3], RELEASE SOFTWARE (P)
Compiled Mon 07/10/2023 04:28:59 by rel
Current ROMMON image : Primary
C9200CX-12T-2X2G platform with 4194304 Kbytes of main memory
boot: attempting to boot from [flash:cat9k_lite_iosxe.17.09.06a.SPA.bin]
boot: reading file cat9k_lite_iosxe.17.09.06a.SPA.bin
ERROR: failed to boot from flash:cat9k_lite_iosxe.17.09.06a.SPA.bin (Invalid Parameter)
Please wait while the system restarts.
WARNING: Bootable URL's in BOOT variable not found or exhausted.
Please check the ROMMON configuration or boot command usage.
switch: set
ABNORMAL_RESET_COUNT=0
BAUD=9600
BOOT=flash:cat9k_lite_iosxe.17.09.06a.SPA.bin;
BOOT_DEVICE_MODE=catalyst
BSI=0
MAC_ADDR=A0:BC:6F:DF:A8:80
MODEL_NUM=C9200CX-12T-2X2G
MOTHERBOARD_SERIAL_NUM=..........
NO_CONSOLE=0
RANDOM_NUM=756888282
ROMMON_BOARDID=0x33D
ReloadReason=Image Install RET_2_RCALTS=1709238225
SWITCH_NUMBER=1
SYSTEM_SERIAL_NUM=..........
TEMPLATE=advanced
USB_DISABLE=0
switch:
05-19-2025 03:39 PM
Post the complete output to the command "sh run | include boot". I suspect the boot variable statement is incorrect.
05-19-2025 03:40 PM
@Hasna wrote:UPTIME CONTINUOUS INFORMATION -------------------------------------------------------------------------------- Time Stamp | Reset | Uptime MM/DD/YYYY HH:MM:SS | Reason | years weeks days hours minutes -------------------------------------------------------------------------------- 04/17/2025 09:15:48 Power Failure or Unknown 0 0 0 0 30 04/22/2025 08:48:17 Power Failure or Unknown 0 0 1 5 0 04/27/2025 10:01:06 Power Failure or Unknown 0 0 0 0 10 04/27/2025 16:36:58 Power Failure or Unknown 0 0 0 6 0 04/28/2025 06:40:56 Power Failure or Unknown 0 0 0 0 5 04/28/2025 08:03:35 Reload Command 0 0 0 1 0 04/28/2025 08:56:47 Power Failure or Unknown 0 0 0 0 35 05/07/2025 08:01:24 Power Failure or Unknown 0 0 0 6 0 05/07/2025 08:04:45 Power Failure or Unknown 0 0 0 0 0 05/07/2025 13:11:16 Power Failure or Unknown 0 0 0 0 55 05/07/2025 14:03:04 Power Failure or Unknown 0 0 0 0 45 05/07/2025 14:12:50 Reload Command 0 0 0 0 5 05/07/2025 14:26:50 Power Failure or Unknown 0 0 0 0 5 05/07/2025 14:31:41 Reload Command 0 0 0 0 0 05/11/2025 10:37:09 Power Failure or Unknown 0 0 0 0 10 05/12/2025 08:27:13 Power Failure or Unknown 0 0 0 1 0 05/19/2025 10:25:20 Reload Command 0 0 0 0 0
The switch has power issue and the last reboot, on 19 May 2025, was because someone entered the "reload" command.
05-19-2025 03:13 AM
Can you check "show boot" , Manual boot should be " no"
05-19-2025 03:28 AM
Switch#show boot
Switch 1
Current Boot Variables:
BOOT variable = flash:cat9k_lite_iosxe.17.09.06a.SPA.bin;
Boot Variables on next reload:
Manual Boot = no
Enable Break = no
Boot Mode = DEVICE
iPXE Timeout = 0
05-19-2025 03:51 AM
You have already checked with 17.12.05 and 17.09.06a and still switch enters ROMMON mode.
Boot variable seems OK,it is booting with .bin file.
I would suggest please upgrade it using "INSTALL" mode instead using "BUNDLE" mode.
05-19-2025 04:54 AM - edited 05-19-2025 04:57 AM
i'm on the testing phase of the 17.09.06a
Please what's the difference between the two mode ?
05-19-2025 04:02 AM
9200CX is a compact switch. Post the complete output to the following commands:
dir
sh log on switch active uptime detail
sh log on switch active message detal
