C9200L-24P POE+ Issue
Dears,
need help for the below issue,
trying to connect TPLink POE spliter tp-link tl-poe10r with the switch C9200L-24P with Power 600Wat should be able for POE+ and support 8023af & 802.3at as pet data sheet.
but its not powering up unfortunately and just trying to negotiate power 15.4 not 3.0 as per tplink needs.
Tplink model datasheet: https://www.tp-link.com/us/business-networking/accessory/tl-poe10r/
also i tried to power it with extreme x440 and powered up successfully as per attached.
could any one support?
8 Replies 8
ammahend
try setting static power on c9200
-hope this helps-
i tried to disable poe all ports except the port that i am using it and configured static power with the same issue unfortunately.
liviu.gheorghe
Hello @Mina Hosny Edward ,
from the info you provided about the TPLink POE spliter tp-link tl-poe10r and your setup, I have some questions:
1. Is your setup like the one in the attached image? Have you set the voltage selector to the correct value for the device you want to power?
2. What is the model of Cisco 9200 you are trying to use?
3. What is the device, vendor and model, you are trying to power up?
Regards, LG
*** Please Rate All Helpful Responses ***
yes the same device that i powered up with Extreme switch X440-8P
yes i set the voltage for the TPlink to be 12v without connecting the cable as like screenshot attached.
note : i am trying to connect the TPlink spliter without connecting the end device that will be used to power on.
tried to power tplink spliter with C9200L-24P include power supply 600W and C9300-48P with double power supply 750.
tp-link tl-poe10r poe splitter
https://www.tp-link.com/eg/business-networking/accessory/tl-poe10r/
also find the attached screenshot for the tplink while its connected to xtreme x440-8p
Nitgen UBIO X Pro Lite
NITGEN
klnnnnng
Dear Mina,
what is the output of the commands:
show power inline
show power inline gigabitEthernet 1/0/X detail
show logging - anything suspicious here?
Normally devices dynamically negotiation PoE power over CDP/LLDP.
show power inline
Switch#show power inline
Module Available Used Remaining
(Watts) (Watts) (Watts)
1 370.0 0.0 370.0
Interface Admin Oper Power Device Class Max
(Watts)
Gi1/0/1 off off 0.0 n/a n/a 30.0
Gi1/0/2 off off 0.0 n/a n/a 30.0
Gi1/0/3 off off 0.0 n/a n/a 30.0
Gi1/0/4 off off 0.0 n/a n/a 30.0
Gi1/0/5 off off 0.0 n/a n/a 30.0
Gi1/0/6 off off 0.0 n/a n/a 30.0
Gi1/0/7 off off 0.0 n/a n/a 30.0
Gi1/0/8 off off 0.0 n/a n/a 30.0
Gi1/0/9 off off 0.0 n/a n/a 30.0
Gi1/0/10 off off 0.0 n/a n/a 30.0
Gi1/0/11 off off 0.0 n/a n/a 30.0
Gi1/0/12 off off 0.0 n/a n/a 30.0
Gi1/0/13 off off 0.0 n/a n/a 30.0
Gi1/0/14 off off 0.0 n/a n/a 30.0
Gi1/0/15 off off 0.0 n/a n/a 30.0
(Watts)
Gi1/0/16 off off 0.0 n/a n/a 30.0
Gi1/0/17 off off 0.0 n/a n/a 30.0
Gi1/0/18 off off 0.0 n/a n/a 30.0
Gi1/0/19 off off 0.0 n/a n/a 30.0
Gi1/0/20 off off 0.0 n/a n/a 30.0
Gi1/0/21 off off 0.0 n/a n/a 30.0
Gi1/0/22 off off 0.0 n/a n/a 30.0
Gi1/0/23 off off 0.0 n/a n/a 30.0
Gi1/0/24 auto off 0.0 n/a n/a 30.0
Switch#show power inline gigabitEthernet 1/0/24 detail
Interface: Gi1/0/24
Inline Power Mode: static
Operational status: off
Device Detected: no
Device Type: n/a
IEEE Class: n/a
Discovery mechanism used/configured: Ieee and Cisco
Police: off
Power Allocated
Admin Value: 30.0
Power drawn from the source: 30.0
Power available to the device: 30.0
Actual consumption
Measured at the port: 0.0
Maximum Power drawn by the device since powered on: 0.0
Absent Counter: 0
Over Current Counter: 0
Short Current Counter: 0
Invalid Signature Counter: 0
Power Denied Counter: 0
--More--
*Feb 19 06:53:01.479: %ILPOWER-5-IEEE_DISCONNECT: Interface Gi1/0/24: P d
Power Negotiation Used: None
LLDP Power Negotiation --Sent to PD-- --Rcvd from PD--
Power Type: - -
Power Source: - -
Power Priority: - -
Requested Power(W): - -
Allocated Power(W): - -
Four-Pair PoE Supported: No
Spare Pair Power Enabled: No
Four-Pair PD Architecture: N/A
Syslog logging: enabled (0 messages dropped, 1 messages rate-limited, 0 flushes, 0 overruns, xml disabled, filtering disabled)
No Active Message Discriminator.
No Inactive Message Discriminator.
Console logging: level debugging, 309 messages logged, xml disabled,
filtering disabled
Monitor logging: level debugging, 0 messages logged, xml disabled,
filtering disabled
Buffer logging: level debugging, 309 messages logged, xml disabled,
filtering disabled
Exception Logging: size (4096 bytes)
Count and timestamp logging messages: disabled
File logging: disabled
Persistent logging: disabled
No active filter modules.
Trap logging: level informational, 195 message lines logged
Logging Source-Interface: VRF Name:
Log Buffer (4096 bytes):
51:20.478: %ILPOWER-5-IEEE_DISCONNECT: Interface Gi1/0/24: PD removed
*Feb 19 06:51:21.478: %ILPOWER-7-DETECT: Interface Gi1/0/24: Power Device detected: IEEE PD
*Feb 19 06:51:22.480: %ILPOWER-5-IEEE_DISCONNECT: Interface Gi1/0/24: PD removed
*Feb 19 06:51:23.478: %ILPOWER-7-DETECT: Interface Gi1/0/24: Power Device detected: IEEE PD
*Feb 19 06:51:24.479: %ILPOWER-5-IEEE_DISCONNECT: Interface Gi1/0/24: PD removed
*Feb 19 06:51:25.479: %ILPOWER-7-DETECT: Interface Gi1/0/24: Power Device detected: IEEE PD
*Feb 19 06:51:26.480: %ILPOWER-5-IEEE_DISCONNECT: Interface Gi1/0/24: PD removed
*Feb 19 06:51:27.478: %ILPOWER-7-DETECT: Interface Gi1/0/24: Power Device detected: IEEE PD
*Feb 19 06:51:28.480: %ILPOWER-5-IEEE_DISCONNECT: Interface Gi1/0/24: PD removed
*Feb 19 06:51:29.479: %ILPOWER-7-DETECT: Interface Gi1/0/24: Power Device detected: IEEE PD
*Feb 19 06:51:30.478: %ILPOWER-5-IEEE_DISCONNECT: Interface Gi1/0/24: PD removed
*Feb 19 06:51:31.477: %ILPOWER-7-DETECT: Interface Gi1/0/24: Power Device detected: IEEE PD
*Feb 19 06:51:32.479: %ILPOWER-5-IEEE_DISCONNECT: Interface Gi1/0/24: PD removed
*Feb 19 06:51:33.478: %ILPOWER-7-DETECT: Interface Gi1/0/24: Power Device detected: IEEE PD
*Feb 19 06:51:34.479: %ILPOWER-5-IEEE_DISCONNECT: Interface Gi1/0/24: PD removed
*Feb 19 06:51:38.487: %SYS-5-CONFIG_I: Configured from console by console
*Feb 19 06:52:38.702: %SYS-5-CONFIG_I: Configured from console by console
*Feb 19 06:52:50.477: %ILPOWER-7-DETECT: Interface Gi1/0/24: Power Device detected: IEEE PD
*Feb 19 06:52:51.478: %ILPOWER-5-IEEE_DISCONNECT: Interface Gi1/0/24: PD removed
*Feb 19 06:52:53.477: %ILPOWER-7-DETECT: Interface Gi1/0/24: Power Device detected: IEEE PD
*Feb 19 06:52:54.477: %ILPOWER-5-POWER_GRANTED: Interface Gi1/0/24: Power granted
*Feb 19 06:52:55.480: %ILPOWER-5-IEEE_DISCONNECT: Interface Gi1/0/24: PD removed
*Feb 19 06:52:56.477: %ILPOWER-7-DETECT: Interface Gi1/0/24: Power Device detected: IEEE PD
*Feb 19 06:52:57.478: %ILPOWER-5-IEEE_DISCONNECT: Interface Gi1/0/24: PD removed
*Feb 19 06:52:58.478: %ILPOWER-7-DETECT: Interface Gi1/0/24: Power Device detected: IEEE PD
*Feb 19 06:52:59.479: %ILPOWER-5-IEEE_DISCONNECT: Interface Gi1/0/24: PD removed
*Feb 19 06:53:00.478: %ILPOWER-7-DETECT: Interface Gi1/0/24: Power Device detected: IEEE PD
*Feb 19 06:53:01.479: %ILPOWER-5-IEEE_DISCONNECT: Interface Gi1/0/24: PD removed
*Feb 19 06:53:03.477: %ILPOWER-7-DETECT: Interface Gi1/0/24: Power Device detected: IEEE PD
*Feb 19 06:53:04.477: %ILPOWER-5-POWER_GRANTED: Interface Gi1/0/24: Power granted
*Feb 19 06:53:05.478: %ILPOWER-5-IEEE_DISCONNECT: Interface Gi1/0/24: PD removed
*Feb 19 06:53:06.479: %ILPOWER-7-DETECT: Interface Gi1/0/24: Power Device detected: IEEE PD
*Feb 19 06:53:07.478: %ILPOWER-5-IEEE_DISCONNECT: Interface Gi1/0/24: PD removed
*Feb 19 06:53:08.478: %ILPOWER-7-DETECT: Interface Gi1/0/24: Power Device detected: IEEE PD
*Feb 19 06:53:09.479: %ILPOWER-5-IEEE_DISCONNECT: Interface Gi1/0/24: PD removed
*Feb 19 06:53:10.477: %ILPOWER-7-DETECT: Interface Gi1/0/24: Power Device detected: IEEE PD
*Feb 19 06:53:11.478: %ILPOWER-5-IEEE_DISCONNECT: Interface Gi1/0/24: PD removed
*Feb 19 06:53:12.478: %ILPOWER-7-DETECT: Interface Gi1/0/24: Power Device detected: IEEE PD
*Feb 19 06:53:13.480: %ILPOWER-5-IEEE_DISCONNECT: Interface Gi1/0/24: PD removed
*Feb 19 06:53:14.477: %ILPOWER-7-DETECT: Interface Gi1/0/24: Power Device detected: IEEE PD
*Feb 19 06:53:15.479: %ILPOWER-5-IEEE_DISCONNECT: Interface Gi1/0/24: PD removed
*Feb 19 06:53:17.478: %ILPOWER-7-DETECT: Interface Gi1/0/24: Power Device detected: IEEE PD
*Feb 19 06:53:18.478: %ILPOWER-5-POWER_GRANTED: Interface Gi1/0/24: Power granted
*Feb 19 06:53:19.479: %ILPOWER-5-IEEE_DISCONNECT: Interface Gi1/0/24: PD removed
*Feb 19 06:53:20.479: %ILPOWER-7-DETECT: Interface Gi1/0/24: Power Device detected: IEEE PD
*Feb 19 06:53:21.480: %ILPOWER-5-IEEE_DISCONNECT: Interface Gi1/0/24: PD removed
*Feb 19 06:53:22.479: %ILPOWER-7-DETECT: Interface Gi1/0/24: Power Device detected: IEEE PD
*Feb 19 06:53:23.480: %ILPOWER-5-IEEE_DISCONNECT: Interface Gi1/0/24: PD removed
Switch#
i am enabling lldp transmit and recieve on port 24 and on globale mode also.
In this case, CDP which is enabled by default won't be of much help - I don't expect that the Nitgen UBIO X Pro Lite is implementing CDP, but LLDP might help in this situation. Enable LLDP globally on the switch and see if the situation changes.
Regards, LG
i am enabling lldp transmit and recieve on port 24 and on globale mode also with the same behavior.
