C9200L-24T-4X Boot Problem
Junak
Initializing Hardware...
System Bootstrap, Version 17.9.1r [FC13], RELEASE SOFTWARE (P)
Compiled Thu 06/08/2023 20:36:25 by rel
Current ROMMON image : Primary
C9200L-24T-4X platform with 2097152 Kbytes of main memory
boot: attempting to boot from [flash:packages.conf]
boot: reading file packages.conf
*** Stack adapter authentication failed on stack port 1 on switch 2 ***
Stack Adapter Auth Fail : SIF_SERDES_CABLE_EASTBOUND
*** Stack adapter authentication failed on stack port 2 on switch 2 ***
Stack Adapter Auth Fail : SIF_SERDES_CABLE_WESTBOUND
Both links down, not waiting for other switches
Switch number is 2
Chassis 2 reloading, reason - Active/standby selection failed in 1+1 Mode
May 12 06:31:28.313: %PMAN-5-EXITACTION: C0/0: pvp: Process manager is exiting: reload cc action requested
May 12 06:31:28.860: %PMAN-5-EXITACTION: F0/0: pvp: Process manager is exiting: reload fp action requested
May 1705: %PMAN-5-EXITACTION: R0/0: pvp: Process manager is exiting: rp processes exit with reload switch code
remove the stack cable but no change the switch.Os not load this and usb not supported?
Contact Cisco TAC and organize for an RMA.
CSCvs42280
FN70506 - Authentication Failure Observed on C9200/C9200L Switches When a Stacking Cable, Stack Adapter, or Network Module Is Inserted in the Switch
