C9200L Config Not Saving on Reboot
iclare
I'm trying to set up a C9200L-24T-4X-E-RF switch. I'm setting it up using the following commands but it seems the configuration is not being saved between reboot.
switch: boot flash:/cat9k_lite_iosxe.17.03.05.SPA.bin
Switch>enable
Switch#config t
Switch(config)#boot system flash:/cat9k_lite_iosxe.17.03.05.SPA.bin
Switch(config)#end
Switch#copy run start
Switch#wr
Switch#reload
I expect to be rebooted into IOS-XE at the Switch> prompt but I'm brought back to switch:
Ian
2 Accepted Solutions
Mark Elsen
- Use the full write mem command to be certain. Further check this document and review (needed) settings (or set) accordingly : https://www.cisco.com/c/en/us/support/docs/switches/catalyst-9300-series-switches/216850-configuration-register-equivalent-clis-i.html
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
juancuffaro
I had the same problem and I fixed it by getting into rommon and at the prompt type:SWITCH_IGNORE_STARTUP_CFG=0
Then reboot.
Mark Elsen
 M.
       Beauty and terror
      Just keep going
       No feeling is final
juancuffaro
Then reboot.
This fixed the issue I've been troubleshooting for days. Thank you!
